Hi gents,
as some of you know, I bought MBES2's old car from a chap that bought it from MBES2 and had it for a few months.
In the initial fore sale post, the car was listed with Apexi filter, however when I now checked it has a blue cone filter on which I could not find any naming at all so probably cheap.
Furthermore the filter looks completely dry? In my experience they are normally somewhat oily?
As I have trouble with a P0130 fault code, which apparently sometimes is linked to the MAF playing up, and I was considering getting a new MAF to check if it is indeed the MAF, maybe if the car has been run with an inadequate filter, no wonder the MAF would be toast.
Either way, if I fit a new MAF, I want to make sure it lasts.
As I have an 80 mm MAF, if I wanted to go back to an OEM air box how would you make the connection as I assume the air box has a different diameter?
Or is there some sort of cone filter which does not kill of the MAF sensors?
Is the air box specific for the VX220 Turbo or can it be taken from another model?
Best source for air box? I guess Liz on here?
Thanks guys!
/C
