*new Build Negotiating A Daily Rate, Pls Help!
Posted 14 June 2017 - 12:08 PM
Posted 14 June 2017 - 12:42 PM
my brother ran a small build company , all sorts from small extensions to larger golf complex stuff
did two jobs for me
average cost per person per day between 200 and 240
mulitiskilled
the only suggestion i would say is have an agreed cost per job, and if any changes along the way due to unforseen problems that it is carried out as apropoer change and documented and have sign offs for each critical stage as you would when buying anything of value
hope this helps
Posted 14 June 2017 - 01:27 PM
Did a self build here so costs are probably not similar enough to make a comparison but I simply asked for a price to go from start to bare shell with electrics, plumbing, tiling etc. The overrun was horrendous despite taking everything I could think of into account, the English architect lied from day one and the penalty clause for lateness was ignored which I had been part of the contract, had been omitted. Yes I should have gone through it line by line myself, another lesson learned! So, all I would say is make sure the penalty clause for lateness is included!!
Posted 14 June 2017 - 01:29 PM
Did a self build here so costs are probably not similar enough to make a comparison but I simply asked for a price to go from start to bare shell with electrics, plumbing, tiling etc. The overrun was horrendous despite taking everything I could think of into account, the English architect lied from day one and the penalty clause for lateness, which I had been assured was part of the contract, had been omitted. Yes I should have gone through it line by line myself, another lesson learned! So, all I would say is make sure the penalty clause for lateness is included!!
Posted 14 June 2017 - 02:56 PM
I am in the industry and absolutely despise day rates, get a price for the works and you know where you stand, being a new build i should be pretty straightforward to price. I am just finishing my own new build and the only "raised voices" have been over day rates and that was with a mate, what happens if they finish half hour early/start half hour late/sit around for an hour at lunch, plus i have no idea how anyone can budget if they dont know the price.
Some guys will zero rate, some guys wont, it depends on their accountants (i.e some accountants cant be bothered), however as you say you can claim it back at the end of the build, i would very much suspect with how he has described the job he will be wanting "cash".
Also do not forget, although multi trained, you will be needing gas safe and electrical certificates so make sure you see their relevant paperwork.
Sorry to sound negative but i have seen many people bitten in the past by day rates.
If you still want to go down day rates:
Plumber £200
Chippie £150-£175
Sparky £200-£250
Plasterers £150
Decorating £125-£150
Tilers £25-£35 per sqr metre.
Edited by Jetpilot, 14 June 2017 - 03:00 PM.
Posted 15 June 2017 - 02:24 PM
Definitely get a fixed price lump sum deal, preferrably with a Bill of Quants if you can get one out of him.
If he's even remotely competent he should be able to price an extension from shell to completion.
I've got 4 jobs live in London at the minute so i'll have plenty of day works on file as a point of reference, they won't be comparable in size but they'll give a general idea of what you're looking at, if you did go down that route.
If he give you a L/S price and you want an eye casting over it, just shout up.
(and good luck getting a decent Plasterer in London for £150/day, or a painter for that matter!)
Posted 15 June 2017 - 04:40 PM
Posted 03 July 2017 - 05:06 PM
I decided to do the sensible thing and take the advice given Thanks everyone!
Im being asked for a scope plans etc for the carpenter to price up….I take it he means scope of works.
How would I drum up a scope for the following trades to price up.
-Carpenter…specify on plans height & width of pocket doors… Plans indicating floor area for flooring….skirting boards…confirm positions of all
stud walls…confirm stairs type open tread/closed tread. Have I missed anything?
-Plumber…specify position of toilets/sinks/wetrooms/taps…show location for utility room to house boiler etc….
-electrician Show points plugs…switches…spot lights…network points…central distribution area.
I will put up some pics of the site tomorrow. its has a man cave :0)
Posted 04 July 2017 - 04:44 PM
Pictures! taken me 2 years to get to this stage...Ive been stung by trades along the way.... steel guys got all of the roof steel angles wrong, 6 months of fighting to get then to admit fault and rectify.this build has taken the life out of me, im sure it will be worth it in the end. The basement team were great had them on a day rate, everyone else after Brickie/roofer/steel guys disaster.
[/URL]
[/URL]
Posted 04 July 2017 - 04:45 PM
[/URL]
[/URL]
Posted 04 July 2017 - 04:58 PM
Thanks mate i will drop you a pm.
any recommendation on trades men , will be much appreciated.
