Hi everybody
first, excuse my english, i'm french
I bought a complete supercharger kit to batman recently but i have an engine with "small conrods" (my engine number begin with TA so it's a USA engine not germany...)
I would like to change internals for forged parts and i need your helpso if you could answer few question i will appreciate a lot!!
1) Should i choose wiseco 8:9 or 10:0?
i saw this kit in US:http://realstreetper...-86mm-8-91.html
Do you confirm that pistons rings and conrods screws are included in this kit (i think in small white box)?
Because it seems that conrods bearing are not supply in this kit, do you have an advice for choosing a supplier for conrods bearing?
2) I have to change the cylinder head gasket. Should i buy an OEM gasket or should i choose a "special" gasket? Any link for that?
3) I have to change cylinder head stud. do you think i should buy oem stud or this kind of kit: http://realstreetper...cotec-2-2L.html
4) I imagine it could be a good idee to change timing chain kit during this intervention. On my previous vx220, i bought FAI kit but i found the quality not really good (one gear was not OK so i keeped my oem gear and use only tensioner, chain guides and chain)
Wich timing chain kit do you use?
3) I'm trying to do a part list for this intervention, could you please say to me if i'm forgeting something?
-86mm (8:9 or 10:0?) WISECO pistons/eagle 5,765" conrods
- New cylinder head stud kit
- New cylinder head gasket
- Conrods bearing
- NEw damper pulley screw
- New camshaft gear screw
- new oil pan gasket
- new valve cover gasket
- new timing chain kit with z20net tensioner
MAny thanks for your help guys
