Accelerator
Posted 01 July 2017 - 12:57 PM
I've rebuilt my vx completely, and now I have the engine back in and idling beautifully, sadly the pedal does nothing. Have had the usual plugs off and on a few times and contact sprayed them (plus the one on actual pedal) but not a sausage.
When idling the throttle butterfly is twitching a little which suggests it's 'alive'.
The alarm siren isn't wired but that I assume wouldn't be anything to do with it (although I would appreciate if someone could send me a pic of the plug wires for the siren as mine has no plug body.
Now I am no electronic whizz, in fact it bores me senseless, but short of going I to full fault finding mode I'm not sure what to do. It ran fine and drove fine before I rebuilt, and the supercharger was fitted as I bought it.
Any ideas guys and girls?
Cheers!
Posted 01 July 2017 - 03:39 PM
you need to check the wiring connections on the black plug behind the coolant tank
Also a duff MAP sensor can cause no throttle on a SC car
Posted 01 July 2017 - 05:56 PM
Cheers Vocky. Bit fed up trying to fathom it and have sprayed the plugs with contact spray but the MAP could be a clue... Here's hoping! Cheers Sent from my iPhone using Tapatalkyou need to check the wiring connections on the black plug behind the coolant tank Also a duff MAP sensor can cause no throttle on a SC car
Posted 02 July 2017 - 08:20 AM
always buy genuine MAP sensors, the cheap pattern sensors are rubbish
I once tested five pattern MAP sensors and only one worked
Posted 02 July 2017 - 12:45 PM
Cheers. does anyone have a pic of the back of the alarm siren with plug wire colours? Still can't find anything on this Sent from my iPhone using Tapatalkalways buy genuine MAP sensors, the cheap pattern sensors are rubbish I once tested five pattern MAP sensors and only one worked
Posted 02 July 2017 - 01:02 PM
alarm sounder wiring;
pin 1 - not used
pin 2 - blue
pin 3 - black
pin 4 - violet
Posted 03 July 2017 - 09:53 PM
Amazing! However which end is pin 1? Sent from my iPhone using Tapatalkalarm sounder wiring; pin 1 - not used pin 2 - blue pin 3 - black pin 4 - violet
Posted 04 July 2017 - 07:32 AM
Posted 04 July 2017 - 09:38 PM
Excellent, cheers Vocky Sent from my iPhone using Tapatalknumber 1 is nearest the passenger side https://z22se.co.uk/...42#post-1238298
