So here goes. After 4.5 years of ownership and almost exactly 10k miles my VX is up for sale.
Car Details
- 61k miles (only 1.5k in the last 12 months)
- October 2017 vx calendar entry
- Owned by me since Jan 2013
- 6 former keepers
- HPI clear
- Stg 2 supercharged with 250bhp
- 12 Months MOT
- 2 keys and 2 fobs with Red card & ECU code
- The last 4 years of the cars history covered in project thread (see here)
Body work
- Europa Blue
- OEM Europa blue hardtop
- NEW Lotus soft top in blue, from the lotus motorsport auctions last year. Used once before putting hard top back on. Cost £1k+ from Lotus directly (apparently)
Interior
- Full leather interior with leather door cards, seats & centre consol
- Carbon fibre binnacle cover
- New heater from Lotus motorsport auction fitted in the last couple of years. It works well enough but don't expect normal car levels of air flow!
Wheels / Suspension
- Nitron Street series dampers. Fitted at 51k miles
- Currently running 525/425 spring rates but will supply 350/450 as well in case you want to drop back
- TD wheels with Avon ZZR tyres. Tyres were replaced last year and have done 2 track days. Cost £700 and plenty of life left
- Uprated toe links and HCB with high tensile bolts with threads correctly tapped and bolts torqued
Supercharger Conversion
- Converted at 54k miles in July-14 by me
- ECU modified with dutch software
- Revs limited to 6800rpm
- 260bhp (best run on a cool evening) and the most linear torque of any vx SC conversion I've seen (see graph)
- Pro-alloy chargecooler rad and alloy main rad. Single fan to aid air flow
- Dual pass mod on charge cooler inlet
- VXR injectors (running sensible duty cycle)
- Turbo back box with pre-cat removed from NA downpipe
- 1-off SC Belt protector
- Poly engine mounts front and rear
Brakes
- 4-Channel ABS, purchased new from Lotus directly
- EP Ally Belled discs on the front, Brembo standard on the rear with <5k miles
- Pagid RS14 pads all round with plenty of life
- Brake cooling pipes to front discs
Servicing bits:
- Full details and log in my project thread but key bits below. I also have a fat folder with receipts and dates/mileage for all the work
- 6/17 - 60,803 miles, Oil and filter change (Shell Helix Ultra)
- 10/15 - 58k miles - Cam chain changed by vocky
- N/S wheel bearing recently fitted using Elise parts (FAG) bearing (less than 20 miles ago)
- 2/5/15 - All ball joints replaced and new rear wheel bearings (EP again). Also coated wishbones in hammerite and setup the suspension
- 01/16 - New bosch battery with 4 year guarantee
- 29/11/15 - Drive belt and tensioner
- 6/14 54k miles- Oil & filter change
- 9/12 - 51k miles - New steering rack from Lotus, nitrons fitted, setup, oil & fiter (have a £2.5k bill for this service.
MOT mileage
- 2017: 60,747
- 2016: 59,207
- 2015: 56,398
- 2014: 53,882
- 2013: 51,902
- 2012: 49,290
- 2011: 42,386
Bad Bits
- The drivers seat stitching has come undone between the back and the base. On the plus side the bolster is in good shape
- Rear O/S light needs re-sealing
- Brake calipers are different colours. I painted one rear red and I ran out of paint so used silver on the other side. Never got round to sorting it
- Usual stone chips to the bluff front but nothing unexpected for age/mileage
Very fast car that I've used for weekend fun and 3-4 track days per year. I've lapped Snetterton in 2:14 and Brands in 54.7s and regularly overtake all manor of other expensive machinery.
Price is £12.5k and car is located in Grays, Essex
I've always wanted a vx220 and have loved owning it and it's so much better with the supercharger. It's been my weekend and track car but having purchased a Caterham to go racing I'm not using the vx on track so it's become just a weekend car. With 3 children and weekends busy with racing it's just not being used so it's time to say good bye.
Calendar shot:
Power Graph:
This was my last time out on track and the cars only done a couple of hundred miles since then. It gives you an idea of the cars pace vs the various Lotus offerings:
