Pops And Bangs
16 replies to this topic
#1 JohnnyVX220
JohnnyVX220
  • 11 posts
Posted 15 July 2017 - 09:09 PM
Does anyone else's turbo pop and bang? I've got a 3" system and it still doesn't pop, does anyone know if it needs to be mapped in? Cheers in advance Johnny
#2 chickendippers
chickendippers
  • 488 posts
Posted 15 July 2017 - 10:11 PM
Mine did some lovely bangs and flames. Any established Vauxhall mapper should be able to add it to your map with ease, RnD Motorsport, SM Tuning, Rabbid Remaps etc 😊
#3 pete-r
pete-r
  • 2,771 posts
Posted 15 July 2017 - 11:14 PM
Send a PM to siztenboots he can help with your mapping.
Edited by pete-r, 15 July 2017 - 11:14 PM.
#4 Nev
Posted 16 July 2017 - 04:43 AM
Means it's more economical and quieter and your exhaust stuffing will likely survive better. Also it won't scare people when you over take them.
#5 BadCop
BadCop
  • 96 posts
Posted 16 July 2017 - 06:57 AM
Plus the EGT is lower. If you want pops and bangs you better throw fireworks out of the window while driving to get the attention of passengers and cops. :D If you really want to risk the engine and turbo: Just set the timing advance to 0 at throttle closed, deactivate the decel Fuel cut and then fry your valves, Turbo, cat, O2 sensor and exhaust stuffing.
https://youtu.be/JNCmjpUO8AY?t=87
Edited by BadCop, 16 July 2017 - 07:03 AM.
#6 turbo boy
turbo boy
  • 1,161 posts
  • Interests:Cars, fitness, fishing, sports
Posted 16 July 2017 - 07:41 AM
Mine started popping at stage 3. Just every now and then in 3rd gear it makes the most unbelievable bang 💥 😛. Childish but fun...
#7 Ormes
Ormes
  • 4,612 posts
Posted 16 July 2017 - 07:58 AM
Stage 2 decat pops on track and gives some flames but by no means gives the effect of an ak47 on overrun, which I assume you are looking for ;)
#8 -Dab-of-Oppo-
-Dab-of-Oppo-
    Cuntpuffin
  • 3,646 posts
Posted 16 July 2017 - 08:17 AM
Mine gives lift off burbles and bangs on demand with ease, very predictably and manageable on the throttle. Courtenay stage 2 map with Larini, precat delete, and sports cat.
#9 siztenboots
Posted 16 July 2017 - 11:42 AM
you just need to set the minimum ignition timing map to -10 degrees ( or less for very severe lift off bangs ) , for the first two rows of low load and across all the rpm range.
this will then pop bang on over run lift off and if you then lightly touch the throttle to put fuel back will give that blub-blub-blub noise
#10 P11 COV
P11 COV
  • 7,686 posts
Posted 16 July 2017 - 05:37 PM
Mine seems to do it more when cold - does that make sense?
#11 VXT Tim
VXT Tim
    No it's not a Lamborghini!
  • 11,421 posts
Posted 16 July 2017 - 06:48 PM
Mine does it only when warm and only when I change from 1st to 2nd under specific boosting circumstances but the bang is absolutely deafening.
Edited by VXT Tim, 16 July 2017 - 06:49 PM.
#12 Code Monkey
Code Monkey
    forum whore
  • 2,425 posts
Posted 17 July 2017 - 10:50 AM
Pour water on the coil pack, mine always starts to pop and bang when it's on it's way out.
#13 siztenboots
Posted 17 July 2017 - 03:55 PM
Ecu adds a little bit more fuel when engine coolant is cold , similar to the old choke , fuel enrichment.
#14 scw02102
scw02102
  • 1,581 posts
Posted 19 July 2017 - 07:21 PM
mine didn't do much even with both cats removed until I had it mapped in
just get a mapper to do it and it will pop and bang as much as you like
#15 siztenboots
Posted 20 July 2017 - 12:11 PM
So an update, Johnny popped over to the office and we updated the existing map and he had a couple of drives before we got to the desired level of acoustics that worked with his exhaust setup. Having demonstrated how extensive the TeamVXRacing software is , he will soon be back for a 260pack.
#16 SteveA
SteveA
  • 9,158 posts
Posted 20 July 2017 - 03:14 PM
Pops & bangs! FFS where is the face palm emoji
#17 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 20 July 2017 - 05:35 PM
You can get that with a p*ss poor map.. normally the sound of Engine failure lol
