[font="calibri;"]Exterior[/font]
[font="calibri;"]Front clam £700[/font]
[font="calibri;"]Rear clam 500[/font]
[font="calibri;"]Paxdoor £75[/font]
[font="calibri;"]Drivers door £75[/font]
[font="calibri;"]Door lock cover £5[/font]
[font="calibri;"]Front V £90[/font]
[font="calibri;"]Roll Bar £25[/font]
[font="calibri;"]Soft top £350[/font]
[font="calibri;"]Bonnet £50[/font]
[font="calibri;"]Bootlid £50[/font]
[font="calibri;"]Drivers mirror £25[/font]
[font="calibri;"]Pax mirror £25[/font]
[font="calibri;"]Front windscreen seal £30[/font]
[font="calibri;"]Bonnet hinge £30[/font]
[font="calibri;"]Rear drivers spat £40[/font]
[font="calibri;"]Rear pax spat £40[/font]
[font="calibri;"]Crashbox £500[/font]
[font="calibri;"]Rad surround £300[/font]
[font="calibri;"]Front pax headlight mint £400[/font]
[font="calibri;"]Front drivers headlight mint £400[/font]
[font="calibri;"]Headlight brackets £10 each[/font]
[font="calibri;"]Rear pax light mint £250[/font]
[font="calibri;"]Rear drivers light mint £250[/font]
[font="calibri;"]Front drivers arch liner £100[/font]
[font="calibri;"]Rear pax arch liner £80[/font]
[font="calibri;"]Rear drivers arch liner £80[/font]
[font="calibri;"]Interior[/font]
[font="calibri;"]Pedal box £50[/font]
[font="calibri;"]Black leather seats £300[/font]
[font="calibri;"]Seat Frames £40[/font]
[font="calibri;"]Mat bolts £15[/font]
[font="calibri;"]Centre console mint £50[/font]
[font="calibri;"]Seat belts £100[/font]
[font="calibri;"]Main door cards £50[/font]
[font="calibri;"]Silver door cards mint £40[/font]
[font="calibri;"]Door triangle bits silver mint £30[/font]
[font="calibri;"]Dash plates mint £30[/font]
[font="calibri;"]Shoulder pads leather £30[/font]
[font="calibri;"]Steering wheel and airbag £150[/font]
[font="calibri;"]Speak surround £20[/font]
[font="calibri;"]Drivers sill cover £100[/font]
[font="calibri;"]Pax drivers seal £!00[/font]
[font="calibri;"]Cup holder £20[/font]
[font="calibri;"]Handbrake handle £20[/font]
[font="calibri;"]Steering wheel cowl £25[/font]
[font="calibri;"]Steering UJ £25[/font]
[font="calibri;"]Footrest NA £25[/font]
[font="calibri;"]Fog light switch £5[/font]
[font="calibri;"]Main beam switch £5[/font]
[font="calibri;"]Side light switch £5[/font]
[font="calibri;"]Rear fog light switch £5[/font]
[font="calibri;"]Hazard switch £10[/font]
[font="calibri;"]Dash board £80[/font]
[font="calibri;"]Carbon fibre sill protector £20[/font]
[font="calibri;"]Heater panel £15[/font]
[font="calibri;"]Window winders £30[/font]
[font="calibri;"]Speedo £50[/font]
[font="calibri;"]Fuel pump sender £80[/font]
[font="calibri;"]Throttle pedal £80[/font]
[font="calibri;"]Headrest pax £30[/font]
[font="calibri;"]Headrest drivers £30[/font]
[font="calibri;"]Pax headrest rear cover £10[/font]
[font="calibri;"]Drivers headrest rear cover £10[/font]
[font="calibri;"]Mirror triangles £10[/font]
[font="calibri;"]Mint NA carpets £60[/font]
[font="calibri;"]Brakes and suspension[/font]
[font="calibri;"]Complete wishbone set £600[/font]
[font="calibri;"]4 x hubs £100[/font]
[font="calibri;"]Mint NA shocks £200[/font]
[font="calibri;"]Front pax calipers £100[/font]
[font="calibri;"]Front drivers caliper £100[/font]
[font="calibri;"]Rear pax caliper £80[/font]
[font="calibri;"]Rear drivers caliper £80[/font]
[font="calibri;"]Engine bits / other[/font]
[font="calibri;"]Complete Supercharger Kit with pro alloy cc rad, CS ecu imobilser and wiring harness £2500[/font]
[font="calibri;"]Gearbox £100[/font]
[font="calibri;"]Gear cables NA £80[/font]
[font="calibri;"]Miltek backbox and downpipe with sports cat £400[/font]
[font="calibri;"]Fez heater £150[/font]
[font="calibri;"]Grey relay £5[/font]
[font="calibri;"]Bootlid hinges na / turbo £15[/font]
[font="calibri;"]Alarm siren £15[/font]
[font="calibri;"]Yellow boot relay £30[/font]
[font="calibri;"]Fuse box cover £10[/font]
[font="calibri;"]Petrol cap £25[/font]
[font="calibri;"]Brown relay £5[/font]
[font="calibri;"]Pax driveshaft £75[/font]
[font="calibri;"]Drivers driveshaft £75[/font]
[font="calibri;"]Driveshaft guard £15[/font]
[font="calibri;"]Petrol filler hose £20[/font]
[font="calibri;"]Front engine mount £20[/font]
[font="calibri;"]Rear engine mount £20[/font]
[font="calibri;"]Brake servo £50[/font]
[font="calibri;"]Clutch slave cylinder £25[/font]
[font="calibri;"]ABS pump and ecu £25[/font]
[font="calibri;"]oil cooler and hoses £50[/font]
[font="calibri;"]Plenty of other bits aswell, so pm me, cheers. [/font]
Edited by The Batman, 16 July 2017 - 03:37 PM.
