Stripping A Sc/na Vx! Again!
#21
Posted 17 July 2017 - 03:21 PM
#22
Posted 17 July 2017 - 03:45 PM
#23
Posted 17 July 2017 - 06:00 PM
Hi Joe what condition is the drivers sill cover in & i take it its the one with the triangles in
#24
Posted 17 July 2017 - 06:02 PM
#25
Posted 17 July 2017 - 06:41 PM
#26
Posted 17 July 2017 - 07:12 PM
#27
Posted 17 July 2017 - 07:34 PM
My bank balance is thankful it's not Calypso
#28
Posted 17 July 2017 - 08:21 PM
#29
Posted 17 July 2017 - 08:22 PM
#30
Posted 17 July 2017 - 08:55 PM
relay went ages ago bud sorry
someone else is interested in the shocks, will let you know if they fall through
sorry adam all bits you are after have been put a side will let you know if they fall through
chris both fog light brackets are good and yours if you want them
#31
Posted 17 July 2017 - 09:06 PM
#32
Posted 18 July 2017 - 08:49 AM
Not sure I'd want shocks that have fallen through
#33
Posted 18 July 2017 - 09:13 AM
#34
Posted 18 July 2017 - 10:57 AM
front windscreen seal and dash plates back up for sale
#35
Posted 18 July 2017 - 11:23 AM
[font="calibri;"]Exterior[/font]
[font="calibri;"]Front clam £700[/font]
[font="calibri;"]Rear clam 500[/font]
[font="calibri;"]Pax door £75[/font]
[font="calibri;"]Drivers door £75[/font]
[font="calibri;"]Anti rattle door pins £7.50[/font]
[font="calibri;"]Door lock cover £5[/font]
[font="calibri;"]Bonnet £50[/font]
[font="calibri;"]Bootlid £50[/font]
[font="calibri;"]Drivers mirror £25[/font]
[font="calibri;"]Pax mirror £25[/font]
[font="calibri;"]Front windscreen seal £30[/font]
[font="calibri;"]Bonnet hinge £30[/font]
[font="calibri;"]Rear drivers spat £40[/font]
[font="calibri;"]Rear pax spat £40[/font]
[font="calibri;"]Front pax headlight mint £400[/font]
[font="calibri;"]Front drivers headlight mint £400[/font]
[font="calibri;"]Headlight brackets £10 each[/font]
[font="calibri;"]Rear pax light mint £250[/font]
[font="calibri;"]Rear drivers light mint £250[/font]
[font="calibri;"]Front pax arch liner £100[/font]
[font="calibri;"]Front drivers arch liner £100[/font]
[font="calibri;"]Rear pax arch liner £80[/font]
[font="calibri;"]Rear drivers arch liner £80[/font]
[font="calibri;"]Interior[/font]
[font="calibri;"]Pedal box £50[/font]
[font="calibri;"]Centre console mint £50[/font]
[font="calibri;"]Window winders £30[/font]
[font="calibri;"]Main door cards £50[/font]
[font="calibri;"]Steering wheel and airbag £150[/font]
[font="calibri;"]Speak surround £20[/font]
[font="calibri;"]Drivers sill cover £100[/font]
[font="calibri;"]Pax drivers seal £100[/font]
[font="calibri;"]Cup holder £20[/font]
[font="calibri;"]Handbrake handle £20[/font]
[font="calibri;"]Steering wheel cowl £25[/font]
[font="calibri;"]Steering UJ £25[/font]
[font="calibri;"]Footrest NA £25[/font]
[font="calibri;"]Side light switch £5[/font]
[font="calibri;"]Rear fog light switch £5[/font]
[font="calibri;"]Dash board £80[/font]
[font="calibri;"]Carbon fibre sill protector £20[/font]
[font="calibri;"]Heater panel £15[/font]
[font="calibri;"]Speedo £50[/font]
[font="calibri;"]Throttle pedal £80[/font]
[font="calibri;"]Headrest pax £30[/font]
[font="calibri;"]Headrest drivers £30[/font]
[font="calibri;"]Pax headrest rear cover £10[/font]
[font="calibri;"]Drivers headrest rear cover £10[/font]
[font="calibri;"]Mirror triangles £10[/font]
[font="calibri;"]Mint NA carpets £60[/font]
[font="calibri;"]Boot carpet £10[/font]
[font="calibri;"]Boot foam £5[/font]
[font="calibri;"]Brakes and suspension[/font]
[font="calibri;"]Front pax calipers £100[/font]
[font="calibri;"]Front drivers caliper £100[/font]
[font="calibri;"]Rear pax caliper £80[/font]
[font="calibri;"]Rear drivers caliper £80[/font]
[font="calibri;"]Engine bits / other[/font]
[font="calibri;"]Complete Supercharger Kit with pro alloy cc rad, CS ecu imobilser and wiring harness and will come with a used pro alloy radiator £2500[/font]
[font="calibri;"]Gearbox £100[/font]
[font="calibri;"]Gear cables NA £80[/font]
[font="calibri;"]Pro alloy radiator £175[/font]
[font="calibri;"]Miltek backbox and downpipe with sports cat £400[/font]
[font="calibri;"]Fez heater £150[/font]
[font="calibri;"]Grey relay £5[/font]
[font="calibri;"]Bootlid hinges na / turbo £15[/font]
[font="calibri;"]Fuse box cover £10[/font]
[font="calibri;"]Brown relay £5[/font]
[font="calibri;"]Pax driveshaft £75[/font]
[font="calibri;"]Drivers driveshaft £75[/font]
[font="calibri;"]Driveshaft guard £15[/font]
[font="calibri;"]Front engine mount £20[/font]
[font="calibri;"]Rear engine mount £20[/font]
[font="calibri;"]Brake servo £50[/font]
[font="calibri;"]Oil cooler and hoses £50[/font]
[font="calibri;"]Clutch slave cylinder £25[/font]
[font="calibri;"]ABS pump and ecu £25[/font]
[font="calibri;"]Fuel pump sender £80[/font]
[font="calibri;"]Plenty of other bits aswell, so pm me, cheers. [/font]
#36
Posted 21 July 2017 - 09:33 PM
UPDATE
[font="calibri, sans-serif;"]Exterior[/font]
Front clam £700
Rear clam 500
Paxdoor £75
Drivers door £75
Door lock cover £5
Roll Bar £25
Bonnet £50 – provisionally sold
Bootlid £50
Drivers mirror £25
Pax mirror £25
Rear pax spat £40
[font="calibri, sans-serif;"]Interior[/font]
Pedal box £50
Seat belts £100
Main door cards £50
Cup holder £20
Steering UJ £25
Footrest NA £25 – provisionally sold
Dash board £80
Window winders £30
Speedo £50
Throttle pedal £80
Headrest pax £30
[font="calibri, sans-serif;"]Brakes and suspension[/font]
Complete wishbone set £600 – provisionally sold
4 x hubs £100 – provisionally sold
[font="calibri, sans-serif;"]Engine bits / other[/font]
Complete Supercharger Kit with pro alloy cc rad £2000
Gearbox £100 – provisionally sold
Gear cables NA £80
Fez heater £150
Grey relay £5
Fuse box cover £10
Petrol cap surround £25
Brown relay £5
Pax driveshaft £75
Brake servo £50
oil cooler and hoses £50
#37
Posted 26 July 2017 - 03:13 AM
#38
Posted 26 July 2017 - 05:48 PM
#39
Posted 26 July 2017 - 05:53 PM
pm's
#40
Posted 30 July 2017 - 10:01 PM
Edited by The Batman, 30 July 2017 - 10:02 PM.
