After fitting a decent splitter to my track car, I now have to take the big speedbumps near my house sideways...
Have to see how that goes, but set me thinking about a ride height lift system. A 1 inch lift should already help a lot in our cars to take speedbumps, ramps etc. safely.
Such ride height systems are not uncommon on expensive supercars and you can now buy such hydraulic lift system from KW suspensions. (the KW HLS kit, still a bit expensive...)
But these KW things seem nothing more than hydraulic preload adjusters that you can buy for most car/motorbike monoshocks. Now how about fitting 2 of these adjusters on the front shocks? Should work for our minimal front weight.
Then drive these with a small hydraulic pump (ABS pump?) and you're set.
Most hydraulic spring perch adjusters are still not cheap, but then saw these for 125 a piece (Hagon):
More people interested in researching this?
