Best Tubby Coilover Kit Mainly For The Road.
Posted 18 September 2017 - 09:14 PM
Posted 19 September 2017 - 04:59 AM
Posted 19 September 2017 - 07:32 AM
I'd have Bilstein refurbish your standard units. I found the VXR Bilsteins (possibly Exige equivalent) too harsh for day to day use. If I was looking at Nitron Street, I'd want to know the spring rates weren't that far enhanced from the original.
Edited by Pidgeon, 19 September 2017 - 07:32 AM.
Posted 19 September 2017 - 08:45 AM
3. Nitron Streets 4. Gaz golds 5. Quantams
As the OP wants to lower the car, that counts out Exige and Standard Billies
Posted 19 September 2017 - 09:08 AM
3. Nitron Streets
4. Gaz golds
5. Quantams
If you can afford to (And for something holding the wheels on the car you really should do) there are only 2 real options out of the ones advised above.
I have a set of Nitrons for track driving but they have remarkebly good damping for the road too, if they had softer spring rates i'd go as far to say that for a VX they would be quite comfortable.
Posted 19 September 2017 - 10:17 AM
Posted 19 September 2017 - 12:19 PM
I had street series and they were good, however for road use I'd still choose Bilsteins. Maybe with front anti roll bar to sharpen up?
Posted 20 September 2017 - 07:47 PM
Posted 20 September 2017 - 08:32 PM
I use Bilsteins with stiff front and rear ARB's - very planted and resistant to roll, but still good on our crap roads..
The car isn't lower however, but OEM-ish ride height (good for roads!)
Edited by Rosssco, 20 September 2017 - 08:32 PM.
Posted 20 September 2017 - 09:40 PM
The plan will be coilovers, hub bolts, toe links and then get a geo done.
Hub bolts won't need replacing. Perhaps you mean hub carrier bolts?
Posted 20 September 2017 - 10:21 PM
Posted 21 September 2017 - 09:04 AM
The cheapest option is to get your OEM Bilstiens refurbished at the factory. They will be like new when they come back and your car will handle vastly better, remember Lotus do know a thing or two about how to make a car handle, they chose those expensive OEM Bilstiens for a good reason.
Lowering the car usually leads to worse handling characteristics (unless you really know what you are doing), if you do so, be aware that you'll likely be making it a slower car...
I once test drove a VX220 with "fresh" OEM suspension that hadn't been fiddled with, it was a very planted car.
Edited by Nev, 21 September 2017 - 09:07 AM.
Posted 04 October 2017 - 10:01 AM
Refurb the standard kit; them Lotus boys is clever with suspension things.
Just had my VXR springs and dampers redone difference was amazing so much more fun to drive.
Posted 04 October 2017 - 12:23 PM
they wont be like brand new, they will look exactly the same as when you sent them in, the only thing they do is the internal gubbins..
we send them off for refurb all the time and i have never had a set back which look any different to how they went in.
Posted 04 October 2017 - 12:25 PM
i would suggest, based on my experiences that Gaz Monotubes are worth a look see..
yep, they perform very well on track, but they also perform excellent on the road too.
Posted 04 October 2017 - 12:37 PM
I have now fitted the Nitron NTR 46mm 1 way dampers and I have to say first experience with them is very positive.
Posted 10 October 2017 - 05:11 PM
Where did i say they would LOOK like new? I said they'd BE like new (ie functionally).
Posted 10 October 2017 - 08:56 PM
So after all that, you didnt go with the best optionI have now fitted the Nitron NTR 46mm 1 way dampers and I have to say first experience with them is very positive.
Posted 10 October 2017 - 09:10 PM
Posted 11 October 2017 - 06:35 PM
I thought NTR were a bit compromised for the road and more track biased?
They are, the Street Series are, er, predictably better on the road. Not to say you can't use NTR's acceptably, especially if you're just an occasional user.
