Oil Filter. O Ring Seal/gasket.
Posted 30 September 2017 - 09:34 AM
Posted 30 September 2017 - 10:10 AM
A set? So do you mean the single rubber O ring or the two large flat sealing washers?
Posted 30 September 2017 - 03:13 PM
If you mean the two flat seals, above and below the sandwich plate, then yes I do. If you mean the O ring that fits the black plastic cap then that is available from Autovaux.
Posted 30 September 2017 - 03:46 PM
Posted 02 October 2017 - 01:43 PM
Posted this morning, many thanks for the business. I have stock if anyone else needs some.
Posted 02 October 2017 - 02:27 PM
These are the ones I use. Never had a problem with them whether fitting them or leaks.Posted this morning, many thanks for the business. I have stock if anyone else needs some.
