P0141 Fault Code
10 replies to this topic
#1 Paulus H
Paulus H
  • 2,063 posts
Posted 06 October 2017 - 09:58 PM
Please could any kind soul explain which o2 sensor this relates to. Or should I change both of them.
Kind regards, Paul
#2 The Batman
Posted 06 October 2017 - 10:16 PM
Post cat lambda
#3 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 07 October 2017 - 08:13 AM
The one after the wheel arch U bend facing towards the rear. Sent from my SM-G903F using Tapatalk
#4 Paulus H
Paulus H
  • 2,063 posts
Posted 07 October 2017 - 06:19 PM
Many thanks chaps!
#5 Ali87
Ali87
  • 1,287 posts
Posted 14 October 2017 - 09:18 PM
Try some lambda cleaner first, saved me changing mine
#6 Paulus H
Paulus H
  • 2,063 posts
Posted 28 October 2017 - 05:27 PM
Thanks everyone. Low speed running is much better now thanks. In fact low speed running is much better than before the warning light came on. It must be that a poorly performing sensor does not trigger the warning light unless it more or less shaggered.
Paul
#7 hairy
hairy
    Moonlander
  • 5,826 posts
Posted 28 October 2017 - 07:15 PM
recs for cleaner Ali?
#8 Ormes
Ormes
  • 4,612 posts
Posted 29 October 2017 - 09:53 AM
Can somebody shed some light on why a shagged post cat lambda would cause rough running?... I appreciate that if it fails the ECUs emmissions check, it will may run in a 'safe' callibration causing rough running... is this the only cause?  I would have thought that would be pretty binary though, and trigger the EML?
#9 james4563
james4563
  • 268 posts
Posted 29 October 2017 - 12:16 PM
Doesn't the sensor have affect on fueling. Hence the poor running? My friends MR2 turbo had a bad O2 sensor and it was 40bhp down on power on a Dyno. Once replaced engine was so much smoother. I think it was in a safe map, massive overfueling. Or is that only the precat sensor?
#10 Ali87
Ali87
  • 1,287 posts
Posted 29 October 2017 - 04:35 PM
I used Wynns catalytic converter and lambda cleaner. 10 quid in Halfords. Worked a treat for me
#11 Ormes
Ormes
  • 4,612 posts
Posted 29 October 2017 - 05:21 PM
Pre-cat sensor for fueling. Post cat serves only to confirm to what degree the cat is functioning. (So far as I am aware)
