P 0606 Anyone Shed Some Light On This One
10 replies to this topic
#1 CHILL Gone DUTCH
    IS OUT OF THE POWER RACE !!!
  • 13,529 posts
Posted 12 October 2017 - 06:20 PM
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]DTC P0606 Control Module Internal Performance[/color]
​anyone had any experience with this number noticed FLD did back in 2009
#2 Zoobeef
Zoobeef
    If its not broken, I'll break it
  • 10,849 posts
Posted 12 October 2017 - 06:30 PM
Online talks about ECU issues.
One thing I did find is to unplug the coil pack. It'll throw up different codes but see if that one goes away.
#3 CHILL Gone DUTCH
  • 13,529 posts
Posted 12 October 2017 - 06:37 PM
Cheers worth a go Car Seems to be following wobbler all day
#4 CHILL Gone DUTCH
  • 13,529 posts
Posted 12 October 2017 - 06:56 PM
Throwing a wobbler
#5 chris_uk
    Grease Monkey
  • 9,664 posts
Posted 12 October 2017 - 07:02 PM
Ive fixed that isue before but it was on a turbo.
#6 leevx2.2
leevx2.2
  • 4,781 posts
    getting p!!sed
Posted 12 October 2017 - 07:20 PM
what was it on a turdo then ?
#7 vocky
    vx220 2.5 itb
  • 11,226 posts
Posted 12 October 2017 - 07:36 PM
P0606 can also mean - internal processor fault
might be worth spraying some contact cleaner on the ECU plug pins
#8 FLD
    Filthy Little Deviant
  • 12,853 posts
Posted 12 October 2017 - 08:09 PM
Power supply issue to ecu. LOD plugs possibly. Can't remember which wire I'm afraid.
#9 haggi961
haggi961
  • 5,987 posts
Posted 12 October 2017 - 08:36 PM
Thanks for the ideas and worth a shot. The code only came once on load and then cut the car out. Took a little while to start again. Drove it back home and no problems or codes appeared. So it was a one off which is annoying as I cant see the problem to fix. Reading your post on z22se forum fld you replaced your Ecu? Maybe a new Ecu with fresh install of pro might sort it.
#10 CHILL Gone DUTCH
  • 13,529 posts
Posted 12 October 2017 - 08:39 PM
it wont if its a connector/plug or wire
#11 smiley
  • 9,596 posts
Posted 12 October 2017 - 09:04 PM
https://www.speedste.../z22secodes.pdf
1) MCP Desired Throttle Limiting occuring,
OR,
2) ETC software is not executed in proper order.
OR,
3) Software Tasks loops > Schedule Tasks Loop.
OR,
4) Loss of SPI communication from the MCP.
OR,
5) Average MCP SOH Toggle: 1.45 ms < x < 2.42 ms .
OR,
[color=#ff0000;]6) TPS or APPS Minimum Learned Values fail compliment check.
OR,
7) TPS or APPS Minimum Learned Values fail range check.[/color]
OR,
8) Main P Integrity Check Error occurs.
OR,
9) MCP Integrity Check Error occurs.
OR,
10) MCP Integrity Check Error of Main P occurs.
My first bet would also be on starting with a connector check and clean.
