Gearbox Swap
Posted 14 October 2017 - 05:52 PM
Posted 14 October 2017 - 06:04 PM
Posted 14 October 2017 - 06:22 PM
Drop Glenn Wood a message on the Facebook group, he did his yesterday by the looks of things so could give you some helpful info.
Posted 14 October 2017 - 06:28 PM
horrid job
It can be done with the clam in place, but it makes it even harder. Much easier with the clam off.
Remove NSR suspension and driveshaft, remove downpipe or split the downpipe from the backbox, lower gearbox down so it clears the chassis and then it slides off. I missed a few bits from that
Posted 14 October 2017 - 06:51 PM
Its pretty easy with 2 people fecking heroic doing it on your own!
Posted 15 October 2017 - 05:10 PM
Posted 15 October 2017 - 09:30 PM
You can do it on stands from underneath easy enough, just get it as high as you can. Done it 3 times. Twice in the paddock at Donington and once in the pissing rain at midnight in the paddock at Brands
Posted 16 October 2017 - 11:51 AM
Posted 16 October 2017 - 12:25 PM
no need to touch the coolant system
Posted 16 October 2017 - 12:45 PM
The last box on a turbo took about 3 hours to be ready to lower on my own. That with the tightest front and rear mount bolts I've ever come across.
Posted 16 October 2017 - 12:46 PM
If you are doing it in situ, relocating the box onto the block is the hard bit.
Posted 16 October 2017 - 12:54 PM
Wow. Dedicated guy. You did it in the pissing rain! How long did that take? I took as least bolts out as possible not wanting to create other problems or disturb anything, left the upper wishbone in and disconnected the driveshaft with the hub and everything attached as one unit. Also took that n/s/r front suspension bracket off for easier access coming out. Did you remove the thermostat? As I was thinking when putting the box back in could create probs. So drained the coolant as well.
The guys from BoT did most of it. Diff went towards the end of one race and we were racing the next day and had a spare box. It was raining and it was 10pm. We had a bit of cover but the water was running down the hill in the paddock like a river. Finished about 1am. Sutol was there if i remember correctly.
Driveshafts out in ten mins each side, just undo the toe link and brake line clamp and hinge the hubs forwards. Dont need to disturb the coolant. Hardest part is maneuvering it to get it to drop out downwards. Also I dont have a boot nor the centre divider between boot and engine compartment holes so access is a bit easier from the top.
Posted 16 October 2017 - 03:52 PM
Posted 16 October 2017 - 03:55 PM
especially if doing the swap on your own
