Light Switches
4 replies to this topic
#1 Goodie
Goodie
  • 191 posts
Posted 19 October 2017 - 06:25 PM
The side light switch on my VX has given up the ghost. Not 'clicky' anymore. I'm about to order one off Ebay , but my question is, out of the switches from The Vectra b, which of the 'square' switches are compatible? Is it just the recirculation and frost swich, or most of the square switches? Ie, the heated window and heated seat switches. Thanks
#2 Harry Hornet
Harry Hornet
  • 4,973 posts
Posted 19 October 2017 - 08:16 PM
do a search on ho wto fix the switch
take apart, some wd40, a cocktail stick and clickty click
take care noto lose small spring
#3 Goodie
Goodie
  • 191 posts
Posted 19 October 2017 - 09:09 PM
do a search on ho wto fix the switch   take apart, some wd40, a cocktail stick and clickty click   take care noto lose small spring
Hi, yes , I tried all that but still not working properly.
#4 smiley
Posted 19 October 2017 - 09:37 PM
Eliz sells new front fog switches. http://www.vx220.org...r/2854-elizp987
They are the same as the sidelight and main beam switch.
You just need to swap the front facade from the old switch to the new switch.
Buy 2 for peace of mind, as another failure will just be around the corner.
If you buy 3, i believe she will send you a personalized christmas card. :happy:
edit, when you remove the facade, be careful. In the highlighted location there is a tiny spring that will try
to make a leap to freedom. There is another on the exact other side.
Edited by smiley, 19 October 2017 - 09:48 PM.
#5 Craig S
Craig S
    DA-DA-DUM!
  • 2,787 posts
Posted 20 October 2017 - 07:41 AM
If you think it is broken try taking it apart they are fairly simple to fix - you have nothing to lose anyway.
