Yokohama - A005 - Medium Compound
11 replies to this topic
#1 Hopegreen
Hopegreen
  • 94 posts
Posted 23 October 2017 - 09:36 AM
Hi,
I use to read a lot looking for infromation/solutions already discussed but today I can't find any information regarding these slick tires.
I've just bought a new set of tires, 190 580 r16 front and 230 610 r17 rear, and I would like to know a start point regarding pressures before this Saturday.
Does someone tried these slicks? I will start with 23 psi front and 25 psi rear after warm up.
Any advice will be welcome.
Kind regards,
HGr
#2 Pidgeon
Pidgeon
  • 5,254 posts
Posted 23 October 2017 - 11:26 AM
I don't think you'll find anyone here who uses slicks :o
#3 chris_uk
Posted 24 October 2017 - 07:00 AM
General ADVAN A005 setup guidelines & Info ([color=rgb(255,0,0);]NOT LOTUS SPECIFIC[/color]):
  • Operating Temperature: 160°F to 220°F
  • Hot Inflation Pressures: High 20s to Low 30s (psi)
  • Camber (recommendation range only):
    • Front: -2.5° to -4.5°
    • Rear: -2.0° to -3.5°
  • Caster: As much positive as possible
#4 Hopegreen
Hopegreen
  • 94 posts
Posted 25 October 2017 - 10:05 AM
Thanks!
I think I'm in the right setup.
I have less front camber maybe (I milled the steering arms 2mm) but not bad.
#5 chris_uk
Posted 25 October 2017 - 10:24 AM
you probably have an extra 1/2 a degree there than normal, you have about 1.70 degrees ish?
#6 Hopegreen
Hopegreen
  • 94 posts
Posted 30 October 2017 - 10:25 AM
Probably I'm close to that number.
Finally it was an awsome weekend I ran 24psi front and 26psi rear in hot.
Never felt the car like this before.
Here some photos and videos to thank you.
Edited by Hopegreen, 30 October 2017 - 10:29 AM.
#7 Hopegreen
Hopegreen
  • 94 posts
Posted 30 October 2017 - 10:26 AM
My fastest lap of the day:
https://youtu.be/gI-c53dVRNw
Edited by Hopegreen, 30 October 2017 - 10:27 AM.
#8 Ormes
Ormes
  • 4,612 posts
Posted 31 October 2017 - 10:26 AM
thumbsup
#9 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 31 October 2017 - 10:38 AM
Looks like a fun circuit, nice flowing sections. Sent from my iPhone using Tapatalk
#10 Acidpopstar
Acidpopstar
  • 3,556 posts
What is the spec of your car? Sent from my iPhone using Tapatalk
#11 Hopegreen
Hopegreen
  • 94 posts
Posted 31 October 2017 - 03:50 PM
BODYWORK
carbon fiber rear bootlid
carbon fiber hardtop
rear difuser
harness bar
omp trescento steering wheel
custom speedometer design
automatic fire extinction
custom rollcage with pipe through dashboard
SUSPENSION
Nitron NTR40 fast road
adjustable anti roll bar
rear upgraded toelink
team dynamics 16/17 (two sets)
milled steering arms
slick yokohama A005 medium
BRAKES
4 pot front EP calippers (modified with Opel design)
front brake discs 295mm ap racing
2 pot rear calippers with elise shop adapter
braided lines
Carbone Lorraine RC6
abs off
ENGINE AND GEARBOX
stage 2 supercharged
dutch software
dual pass mod
astra OPC injectors
chargecooler setrab
big throttle body
itg filter
pro alloy radiator
light flywheel
upgraded clutch
F23 gearbox 4.17
ATB quaife
balance shafts deleted
power flex (front an rear engine mounts)
deCAT
60L proalloy fuelt tank
an6 fuel lines
high flow fuel filter
walbro 255
oil pressure sensor
AFR
oil temperatur sensor
catchtank
updated timing chain
And always thinking in the next bits
#12 Hopegreen
Hopegreen
  • 94 posts
Posted 31 October 2017 - 04:00 PM
I love this circuit but it's a little bit dangerous.
Very fast corners with very close walls.
Here another video of the circuit (testing mclaren 675LT)
https://youtu.be/XaRjldAGMPU
Edited by Hopegreen, 31 October 2017 - 04:01 PM.
