Supercharged Alternator Removal
11 replies to this topic
#1 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 08 November 2017 - 04:38 PM
Hi All,
Got an issue with my alternator light flickering most of the time since SC conversion.  Think I may have left out a screw (like a few others  :blush: ) and need to get the alternator off.  Access is obviously an issue....  Any tips/tricks etc to get it off without removing everything?
TIA
VXed
#2 CHILL Gone DUTCH
Posted 08 November 2017 - 04:40 PM
Can be done through the wheel arch
#3 Rosssco
Rosssco
  • 4,183 posts
Posted 08 November 2017 - 04:44 PM
Disconnect your battery first! (if that doesn't sound too obvious, the live is just very close to the manifold).
Also, remove two short bolts closest to the manifold first, the two longer bolts holding the alt and pulley bracket on.
#4 The Batman
Posted 08 November 2017 - 04:46 PM
Through the wheel arch liner thumbsup You will curse a bit!
#5 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 08 November 2017 - 04:48 PM
Looking forward to it then :lol:
Thanks for the replies all :) :grouphug:
#6 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 08 November 2017 - 05:38 PM
i would take the charger of its only four bolts and remove from the top Duck doing it from wheel arch
#7 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 09 November 2017 - 09:22 AM
Is the manifold not in the way?
#8 Rosssco
Rosssco
  • 4,183 posts
Posted 09 November 2017 - 10:18 AM
The SC snout makes access more tricky from the top. As you'll have the belt off already, four bolts plus four throttle body bolts to remove.
#9 Firthy
Firthy
  • 576 posts
Posted 09 November 2017 - 04:46 PM
Hi All,
TIA
VXed
I had the same issue with mine, tried to save some pennies and brought it of ebay..... Ended up getting a brand new bosch one in the end I'm sure it was the voltage regulator that was the problem.
#10 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 09 November 2017 - 08:28 PM
No
#11 vocky
Posted 10 November 2017 - 10:06 AM
:yeahthat:
#12 FLD
Posted 13 November 2017 - 06:39 PM
:yeahthat: Did mine last year...suspect it may have gone again. It appears the regulator is pish.
