Edited by Blue Boy, 11 November 2017 - 04:23 PM.
Camshaft Sensor Gone Again
Posted 11 November 2017 - 04:20 PM
Posted 11 November 2017 - 05:15 PM
the engine wiring loom could have a broken wire or a bad terminal at the connection plug
Posted 12 November 2017 - 09:37 AM
on the turbo the cs plug is quite prone to collect water , but it is an electrically simple device , where as the wiring loom is now getting old.
if the cs is unplugged then it should start with a wasted spark and wasted fuel injection , so if you had camshaft timing wrong out by a tooth/two this would get it to start.
but you would notice reduced revs
check the single bolt and threadlock it
Posted 13 November 2017 - 11:01 AM
Posted 11 December 2017 - 06:30 PM
Posted 11 December 2017 - 07:22 PM
Posted 12 December 2017 - 09:55 AM
Posted 12 December 2017 - 10:17 AM
The cam sensor is held on with a rather flakey single bolt that holds the sensor bracket with a fair degree of movement/alignment. Be sure that it is located as close to the moving parts as possible, so that it can pick up the pulse. It might be that NVH is loosening and pulling the sensor away from the cams.
Posted 12 December 2017 - 10:42 AM
Posted 12 December 2017 - 10:48 AM
might also be worth checking the crank sensor, as they have been known to play up on the z20le* engines
Posted 12 December 2017 - 01:19 PM
Posted 12 December 2017 - 03:59 PM
Posted 12 December 2017 - 04:38 PM
Posted 12 December 2017 - 04:49 PM
Posted 12 December 2017 - 05:58 PM
Posted 12 December 2017 - 06:27 PM
Just been looking at pics of some z20let engines with cambelt cover off. Im missing the bolt the sits between the forks of the camshaft sensor!!!
So the sensor was held to the head but not located correctly?
Edited by Nev, 12 December 2017 - 06:52 PM.
Posted 12 December 2017 - 08:16 PM
Posted 13 December 2017 - 04:09 PM
but the camshaft sensor will not stop the engine running or starting
Seemingly it does. I can't imagine the ECU being too happy about not knowing what position the cams are as this is surely used to trigger the spark...
Posted 13 December 2017 - 04:44 PM
Posted 13 December 2017 - 09:50 PM
A camshaft sensor going will normally allow the engine to carry on running. You would struggle to restart when stopped though.
