Z22Se Na Tuning
Posted 01 December 2017 - 03:40 PM
Posted 01 December 2017 - 03:53 PM
They make them to order, perhaps no one has ordered them!!
Posted 01 December 2017 - 04:00 PM
Posted 01 December 2017 - 04:58 PM
Posted 01 December 2017 - 07:25 PM
Posted 01 December 2017 - 09:09 PM
Edited by haggi961, 01 December 2017 - 09:10 PM.
Posted 02 December 2017 - 09:58 AM
Looks like an interesting (and far cheaper) alternative to the usual webcon.
I wonder what the performance difference is, as the GSXR engine is less than 1/2 the CC of the Z22... maybe they do some machine work on the TB's to enlarge them?
Posted 02 December 2017 - 12:55 PM
Looks nice at the first sight, but by the time you add ECU, sensors, mapping... to make it plug-n-play, the price is already comparable to WebCon.
Posted 02 December 2017 - 01:03 PM
Posted 06 December 2017 - 04:19 PM
Dont forget the bike rev's twice as high.
This would be great if you were to do it on the cheap, so add some really cheap ECU (megasquairt or VEMS) and then make it a proper DIY conversion. If you're paying someone to do it with high end parts you may as well buy a better kit.
I've used bike carbs and TB's on a few engine builds and they work really well and are cost effective. I built a Volvo 360 and put in a Clio 16v engine with a Williams manifold and GSXR 1100 carbs, was a great conversion and made ~160bhp.
Edited by Mattyboi, 06 December 2017 - 04:19 PM.
Posted 07 December 2017 - 10:57 AM
£35
https://danstenginee...&product_id=507
Then £30 in DCOE flange
https://danstenginee...y&path=59_60_75
lash in some pipe. Cheapy intake for carbs/"usual" TB's
Grab a DTA exp48 as its retro and should be cheap, or if you feel daring, one of the many semi producitonised megasquit setups, pikey win!
Posted 07 December 2017 - 10:25 PM
I was only wondering how are you planning to carry out the drive by cable conversion?
Posted 08 December 2017 - 08:46 AM
Webcon still sell the cable conversion kit for a vx220
Posted 08 December 2017 - 11:35 AM
Posted 08 December 2017 - 11:39 AM
I would keep the DBW throttle and butcher a TB to drive the TBs there are a few examples on you tube. You would just have to try and get obdt to work in Alfa-n all the time which could be tricky.
Any You Tube link to this!
Posted 08 December 2017 - 04:15 PM
I was going to use throttle bodies on my old car but went turbo instead. I do like the idea of throttle bodies and have not seen much on here about Megasquirt. The kit car guys love it and use it loads to convert. Might be my next years project once I finish the winter jobs.
Posted 08 December 2017 - 06:55 PM
Yeah, that seems like the best solution on internet. Before you linked that webcon kit, I thought that a solution with a servo linked to tbs and controlled by data from throttle position sensor. But at the end just replacing the throttle pedal and wiring the cable seems easier and more reliable.
Posted 09 December 2017 - 08:07 PM
Ms isn't used here because it's not expensive enoughI was going to use throttle bodies on my old car but went turbo instead. I do like the idea of throttle bodies and have not seen much on here about Megasquirt. The kit car guys love it and use it loads to convert. Might be my next years project once I finish the winter jobs.
