They will fit ok, bit the springs will be stiffer (around 15% stiffer on the front and 20% stiffer on the rear) and the valving is slightky different. The NA will sit slightky higher and you'll therefore notice a larger wheel arch gap. You can compensate for this slightly on the front by fitting lowering brackets. But not the rear.
Vx Turbo Wheels And Standard Shock Absorbers.
Started by
B1RMA
, Jan 08 2018 05:04 PM
23 replies to this topic
