Posted 17 January 2018 - 05:37 PM
Posted 17 January 2018 - 05:50 PM
A trip to BOT?
Posted 17 January 2018 - 06:48 PM
Posted 17 January 2018 - 07:16 PM
Must be wired wrong as abs on or of shouldn't make any difrence to traction controll .Only 4 wires are used from the abs unit one from each hub sensor .
Posted 17 January 2018 - 07:18 PM
Sounds like it needs setup for your car.
You don't have to plug it into a laptop to set it up just go through all the settings and set it up on Racelogic screen .
Posted 17 January 2018 - 07:38 PM
I presume it depends where your TC unit is wired into on your wheel speed sensors. The 'usual' way to disable the ABS is to effectively break the circuit for one of the wheel speed sensors (by adding a switch in on of the wires). The Racelogic system (like most 4 wheel TC systems I understand) uses the same wheel speed sensor inputs as your ABS system. So by disabling the ABS, you may be disabling the TC input. I presume it would work if the TC sensor wire was connected somewhere in the wheel speed sensor circuit before the switch. Alternatively, if you have a dodgy wheel speed sensor (we've all had them), you will get erroneous signals much like when the ABS system throws a wobbler due to the same issue..
Posted 17 January 2018 - 07:48 PM
Sounds logical
Posted 17 January 2018 - 07:57 PM
find out where your abs switch is in your system first mine is at the abs system itself the yellow wire sounds like yours is one of the signal wires which will send your race logic system into a misfire as it thinks you are loosing traction .
Posted 17 January 2018 - 08:12 PM
Yup, only needed to read the title to come to the same conclusion.Sounds logicalI presume it would work if the TC sensor wire was connected somewhere in the wheel speed sensor circuit before the switch.
Posted 18 January 2018 - 02:51 PM
Edited by dw1, 18 January 2018 - 02:51 PM.
Posted 18 January 2018 - 03:01 PM
have you cut the abs sensor before the TC unit , or after ?
Posted 18 January 2018 - 08:07 PM
Edited by dw1, 18 January 2018 - 08:09 PM.
Posted 19 January 2018 - 08:27 AM
You'll need to provide pics of where the TC wiring intersects too.
Ps.- I'm not a big fan of exposded spade connector for the likes of ABS signals - A little unseen corrosion can result in dodgy signals to the controller.
