Radiator Fan Advice
Posted 25 January 2018 - 08:03 AM
Posted 25 January 2018 - 11:54 AM
Posted 25 January 2018 - 11:56 AM
check the bleed screw on the pipe , easier to make a repair with clam off
Posted 25 January 2018 - 12:05 PM
Posted 25 January 2018 - 12:13 PM
Posted 25 January 2018 - 04:14 PM
The fan will only come on at 106 (or is it 7...?) Celsius, so as long as you are driving along it never comes on. An NA on track you'll have no temp problems even in summer.
I would recommend replacing the fan when doing the radiator because if it seizes (which mine did) you have to do all the work again.
Posted 25 January 2018 - 04:38 PM
Yes but the fan will kick in when you come back into the pits and the car is just sat following a a session on track.
Posted 25 January 2018 - 04:56 PM
I'm thinking of installing one or two puller fans on top of the rad, in replacement of the two pusher fans fitted to my chargecooler pre-rad - can't help but think the fans restrict the natural airflow through the pre-rad and rad to an extent.. I think the latest Loti have adopted this approach (not specifically why).
Posted 26 January 2018 - 11:22 AM
would be interested in that , I run without fans on mine , but it is a problem in southern europe summer > 40 degrees
Posted 26 January 2018 - 11:32 AM
The kit from Elise Parts linked above does that, but I think just a single central mounted fan would be sufficient for the vast majority of Northern European users. Top mount is also easier to service / replace, especially if you've ever had a failed fan mount and seen it dangling inside the front crash box..
Edited by Rosssco, 26 January 2018 - 11:34 AM.
Posted 26 January 2018 - 11:52 AM
The VX bonnet hinge is only mm's above the radiator surface, so don't think the S2 top mounted fan(s) will fit directly...
Posted 26 January 2018 - 12:26 PM
Posted 26 January 2018 - 12:59 PM
That's a good point tbh.. I presume Loti don't use a bonnet hinge design stolen from a shipping container then..
Posted 28 January 2018 - 04:07 PM
Posted 28 January 2018 - 04:27 PM
Posted 01 February 2018 - 04:36 PM
I have wired up a switch on my dash which brings the fan on, use it when sat in traffic on a hot day .
Posted 01 February 2018 - 06:31 PM
Yea it's good idea, pre-emptively switching them on before the water even starts to get hot.
I have a rad switch on my dash too and it's useful for when you've been belting along and then suddenly end up in unexpected traffic etc. I've never seen over 96 degrees on my car as a result and usually it stays under 93 degrees (even in summer after a sprightly run).
Edited by Nev, 01 February 2018 - 06:32 PM.
