Brake Pads Please
Posted 02 February 2018 - 12:48 PM
Posted 02 February 2018 - 12:56 PM
Many would recommend M1155's..! Poor performance could be due to a number of issues (not least, you've gotten used to them) - Operation of calipers (e.g. sticking on one side), contaminated surface or poor condition discs, old or over-heated brake fluid.
Posted 02 February 2018 - 12:58 PM
Posted 02 February 2018 - 12:59 PM
Posted 02 February 2018 - 01:26 PM
Sorry, didn't mean to teach you to suck eggs!
I found RC5+ sharper than M1155's, and a really good pad all round (mostly road use for me), although there is the potential issue of the pad material breaking away from the back plate, which while mainly a historic issue, can be slightly off putting..
Posted 02 February 2018 - 01:27 PM
Even 1144s could lock the wheels easily, tyres always the limitation in my experience...
Posted 02 February 2018 - 01:30 PM
Sorry, simple question but which pads does everyone recommended and from where? Used for fast Road and the occasional track day, currently using 1155's but the brakes aren't as good as they should be? Cheers in advance
Check your servo is getting a strong vacuum, the one-way valve and pipe that feeds it are prone to perish and wild cams with too much overlap can cause inlet manifold vacuum to be poor as well.
Edited by Nev, 02 February 2018 - 01:34 PM.
Posted 02 February 2018 - 01:32 PM
Cheers Nev, I bet those parts are peanuts, I may just swap them as a precaution 👍Check your servo is getting a strong vacuum, the one-way valve and pipe that feeds it are prone to perish.Sorry, simple question but which pads does everyone recommended and from where? Used for fast Road and the occasional track day, currently using 1155's but the brakes aren't as good as they should be? Cheers in advance
Posted 02 February 2018 - 01:35 PM
Posted 02 February 2018 - 01:43 PM
The RC5+ were always a good compromise between road use and decent on track.
Had issues with crumbling and separation from the backing plate a few years back, not sure if they fixed this in their production process ?
Posted 02 February 2018 - 01:47 PM
Posted 02 February 2018 - 01:59 PM
Yep, and with 1155's too, but from an 'aggressiveness' / initial bite / feel POV, they both don't have the initial sharpness of the likes of the RC5+ (IME). Whether this is desirable is purely a personal choice I guess. Point and squirt B-road driving, I like the initial aggressiveness, but more difficult to modulate day - day (and twice the price of 1144's!)..
Posted 02 February 2018 - 02:09 PM
I have RC6 and RC8 and "think" that isn't enough, though in practice they have always stopped me at various hairy moments. These cars are so fast and agile I think the braking on them can sometimes give the perception of being poor in comparison to their other dynamics.
Before I did my brake conversion I was on rc5 I think, and used a phone accelerometer to measure just what was happening. My acceleration was +1.6g, steady cornering was 1.4g, but the braking was "only" -1.4g. Hence the illusion that the brakes "seemed" poor to me, when in fact -1.4g for braking is quite reasonable. Even an NA accelerates bloody quickly until you change into 3rd and can corner hard and could give you this poor braking impression IMO.
Edited by Nev, 02 February 2018 - 02:30 PM.
Posted 02 February 2018 - 02:33 PM
In my experience 1155s need heat before they are any good which (on the road) is probably why they lack initial bite. Get some 1144s back on as their temperature range is much more suited to road driving.
Posted 02 February 2018 - 02:34 PM
Fair enough. I have a very heavy right foot so never have a problem with this!
Posted 02 February 2018 - 02:35 PM
Posted 02 February 2018 - 02:51 PM
A pair of steelies are much cheaper than RC5+'s - you may be onto something!
Posted 06 February 2018 - 04:17 PM
Posted 06 February 2018 - 09:36 PM
This. I loved the m1144's for instant bite and decent braking I loved the m1155's once they had a spot of heat in them for the abuse they could take. I really loved the pfb97's for the face removing braking they offered, but they had dire cold bite. Now this hot/cold into isn't much in many cases, but the 1155's did feel pretty wooden at any tempIn my experience 1155s need heat before they are any good which (on the road) is probably why they lack initial bite. Get some 1144s back on as their temperature range is much more suited to road driving.
Bing (1)
