Technical Advise.
26 replies to this topic
#21 The Batman
  • 29,663 posts
Posted 13 February 2018 - 09:50 PM
:lol:
#22 scottrobertson1990
scottrobertson1990
  • 95 posts
Posted 14 February 2018 - 07:30 AM
Will the original key have to be in the ignition barel for the transponder to send out the signal, or can the key just be next to the transponder for it to work? Just trying to figure out the best way for it to work!
Thanks
#23 fiveoclock
fiveoclock
    I fancy strugs
  • 9,157 posts
Posted 14 February 2018 - 09:18 AM
Thanks
Next to it may work but possibly not. Best for it to be in the barrel. When I built my race car when it still had std ECU I took the chip out of the key and glued it to the ring and it worked.
#24 SteveA
SteveA
  • 8,965 posts
Posted 14 February 2018 - 09:55 AM
If you have the transponder from a different car and are using the original ecu then this is your problem You need matching ecu, immobiliser and chip (in the key)
By Immobiliser do you mean transponder ring?
#25 The Batman
  • 29,663 posts
Posted 14 February 2018 - 12:00 PM
Yes
#26 SteveA
SteveA
  • 8,965 posts
Posted 14 February 2018 - 01:14 PM
thumbsup
#27 MartinS
MartinS
  • 5,047 posts
  • Interests:Track days
    Pubs
    Sausages
Posted 20 February 2018 - 07:31 AM
Good to see there is progress here, be good to get his car back on the road.
Martin S
