All for NA where it matters
Long driveshaft, good condition, new gaiters & re-greased £50
Long driveshaft, good condition, surface rust on the outboard end £40
Long driveshaft, no outer joint, inner joint good condition £20
Short driveshaft, good condition, no large clip on the outer inner gaiter £30
Short driveshaft, good condition £45
Passenger door, silver, would need painting, no seals, with inner handle £50
Drivers door, blue (not sure but 80% sure its coral), good condition, could be used as is, has inner window seal, has inner handle and outer lock push £60
Differential, good when removed, £25
Pair of standard tie rods and ends, £20
New clutch return spring £3
6 x Rear caliper bolts, the one that bends or snaps and then locks the brake £5 for the 6 (wont split)
Pair of aftermarket PTFE oil filter housing/plate sealing rings (the flat ones) £7
Battery clamp £5
Red MSA approved rear towing eye that fits with the M8 bolt that goes into the subframe, bit of paint flaking where the bolt goes £10
Alternator 120A £25
Expansion tank and cap, not discoloured or cracked/crazed £10
Coil pack, two corners broken off (cosmetic only) £10
Red mirror, needs paint £5
Rabiata red passenger side mirror base £5
Drivers side mirror base and mirror, blue (80% sure its Coral), got one of those convex mirrors stuck onto the original mirror glass, good condition, £20
Drivers side door hinge/bar £10
Passenger side door hinge/bar £10
Pair of rear lights, no lenses, one has bolts through it instead of studs at the back, the other has the studs missing, they are rough but they're only £10 pair.
Spal radiator fan, new but been sitting around for about 5 years £15
2 x Relays, the others not the starter relay £5 the pair
Pair of gear cables, good condition, move freely, have new ends on them £80
2 x Mann oil filters £8
2 x Crossland oil filters £8
4 x Team Dynamic centre caps, nearly new, two of them have one tab snapped off but they still fit on tightly, £10
Powerflex purple wishbone bushes, NOT A FULL SET (only 11 short bushes and inserts & 2 long bushes and inserts), in a new set you get 14 short bushes and inserts and 2 long bushes and inserts. Don't know if you can buy single bushes. £100. These are now £300 inc vat a set from Elise Parts.
I can post some parts at buyers expense or collection from Bisley (M3 jnc3) or Kingston, Surrey
Photographs of some parts to follow or message me with your number and I can text them to you.
Edited by fiveoclock, 17 February 2018 - 05:29 PM.
