Supercharged Vx220 In Px For My Westfield.....
1 reply to this topic
#1 Waitey
Waitey
  • 11 posts
Posted 02 March 2018 - 10:42 AM
Anyone interested in a swap?
Spec of my car:
Engine
Rover 1800 K Series
  • Scholar Evo 2 block Omega forged pistons
  • QED lightweight Flywheel
  • Helix clutch
  • REC valves (26/29.5mm) with Colsibro guides
  • Head modified under watchful eye of Dave Andrews (DVA Power) – for breathing and cooling
  • 315cc Injectors
  • Solid lifters with shims
  • Piper 285 cams with vernier wheels
  • EU3 head with wasted spark dual ‘coil on head’
Dry sumped using Pace alloy sump, pump  (2 x scavenge, 1 x pressure) with Pace alloy tower tank
Jenvey Direct to Head Throttle Bodies with ITG filter
Emerald K6 ECU
Powerspeed 4-2-1 all stainless exhaust
All rotating and reciprocating parts were balanced by Steve Smith at Vibration Free
The engine was re mapped by Emerald in Sept 2017 and producing 199bhp @ 8000rpm and 155lb/ft @ 5200rpm.
The engine has done 10 hillclimbs, 2 track days, 3 races and a few road miles since build.
(If starting with a bare engine; just the parts listed above to build an engine to that spec today would cost well over £6,000)
Gearbox
Quaife alloy cased 5 speed Type 9[color=#000000;] with Titan alloy bell housing[/color]
Straight cut, close ratio[color=#000000;] 2.04, 1.54, 1.21, 1.0, 0.87[/color]
Positioned to avoid need for selector extension
Rebuilt by Brian Hill at BGH Geartech and has done 5 events since then
Final Drive
English Axle with 4.4:1 CWP on a Quaife ATB – assembled by Brian Hill
Suspension
Standard Westfield with AVO dampers all round
All joints are poly-bushed, and dampers are rose jointed
Alloy uprights at front
Front adjustable anti roll bar
Front dampers rebuilt by AVO in spring 2013 – one race since.
Brand new Mini lites with new Yokohoma AO48R’s
Brakes
Factory fit floor mounted adjustable bias brakes
Solid disks at Front grabbed by four pot alloy callipers with Hawk ferro-carbon pads
Standard drums at rear
Braided hoses all round
Chassis
Westfield race chassis (i.e. additional bracing, but thinner tube, compared to ‘road’ chassis)
Chassis manufactured in 1999 (so no need for a catalytic converter under MSA rules)
All alloy panels were etch primed prior to painting, and are bonded using PRC (aircraft panel sealant) as well as riveted
Alloy front uprights
Bodywork
Westfield race (lightweight) body work
Playskool carbon aeroscreen, dash, rear deck and ‘diffuser’
Interior
Playskool glassfibre seats
Telemetrix Instruments on Playskool carbon dash
Safety
Lifeline plumbed-in extinguisher
Driver’s 6 point FIA harness
Passenger’s 4 point Willans harness
Caged – full FIA race spec cage
History
The car was SVA’d when built was completed in 2001, and registered on a 1975 age related plate as a consequence of having demonstrable provenance to a donor Ford Escort.
The car remains road and it tax and MOT’d.
Tax is free due to historic status.
It has done somewhere around 4,000 miles in total.
The car has been sprinted and hill climbed and is believed fully legal for RAC MSA approved circuit racing and speed events in UK.
The car will do a 2:14 round Snett 300 on knackered old Kumho V700's with me pedalling it. Deffo a sub 2:08 car in the right hands.
#2 Waitey
Waitey
  • 11 posts
Posted 02 March 2018 - 10:43 AM
Vid of it round Snett. Sorry for the terrible angle...
Edited by Waitey, 02 March 2018 - 10:45 AM.
