Engine Squeak Help
Posted 17 March 2018 - 07:21 PM
Posted 17 March 2018 - 07:27 PM
Wow that sounds odd. Air leak maybe? Intake mani or something?
Posted 17 March 2018 - 09:36 PM
Someone here had a mystery squeak out of their gearbox and it took them years to track it down, I can't remember their name or what actually squeaked for sure, though it might possibly have been incorrect/worn clutch/flywheel parts that caused it. Try searching on here.
Edited by Nev, 17 March 2018 - 09:37 PM.
Posted 17 March 2018 - 11:01 PM
Posted 18 March 2018 - 11:45 AM
Had the belt off still there. New clutch and new slave Sent from my SM-G903F using Tapatalk
Might be some sort of poor interface with the flywheel for some reason.
Posted 18 March 2018 - 11:52 AM
Posted 18 March 2018 - 12:01 PM
It's possible that where the clutch cover mates to the 6 lug mounts on the flywheel that there is some sort of imbalance/asymmetry, which could cause the friction plate to wobble/slip because it is not in perfect alignment perhaps. Could be caused by a slightly warped clutch cover, unequal length lugs, or possibly 1 or more lug bolts not being tightened the same as the others. Clutching at straws I know...
Edited by Nev, 18 March 2018 - 12:04 PM.
Posted 18 March 2018 - 12:17 PM
Posted 18 March 2018 - 12:41 PM
Think your right Nev. The thing that occurs to me is the engine came out of a low mileage automatic car, could the offset on the crank be different ? Sent from my SM-G903F using Tapatalk
I'd suggest swapping out the flywheel initially. I have a spare flywheel here in Bristol (from a Z20LET F23 box) - not sure if that the same as yours.
It's possible crank journal #1 is worn perhaps, causing a wobble on the end of the crank, or maybe the pulley that has an interference fit onto the crank end using a woodruff key is somehow worn/wobby? You could take the sumps out and inspect the bearing shells. Quite a big job.
Or, just ignore the problem until it sounds deadly?!
Edited by Nev, 18 March 2018 - 12:43 PM.
Posted 18 March 2018 - 01:29 PM
Posted 18 March 2018 - 01:48 PM
i have loads of flywheels and clutch configs laying around if you get desperate
Posted 18 March 2018 - 02:06 PM
Posted 18 March 2018 - 02:44 PM
Posted 19 March 2018 - 08:59 AM
Box out again, clutch and flywheel off, nothing to see, no catching of any sort.
I,m going to fit a brace bar to the engine and run it up without the box on. That should rule in or out the components.
Posted 20 March 2018 - 10:29 AM
The noise is in the engine, suspected balance shafts nipping up.
many thanks to Vocky for his advice, now going to balance delete the engine and see if that solves my issue.
Posted 20 March 2018 - 11:32 AM
tricky finding sounds on the VX as the noises seem to travel
Posted 20 March 2018 - 12:28 PM
Agree, even with a mechanics stethoscope the sound just resonates everywhere on the back of the block.
Posted 21 March 2018 - 11:26 AM
Oooh, glad you've eliminated the gearbox.
Edited by Nev, 21 March 2018 - 11:33 AM.
Posted 21 March 2018 - 11:48 AM
How much of a job is that?
