I am selling my complete 2.4L long block which will be out of the car in a week or so. Comes complete and ready to install.
Spec:
[*]2.4L LE5 Gen 2 block on approx. 28k (10.4:1 compression ratio)
[*]Saab cylinder head (modified to fit) with NA cams
[*]Ported exhaust ports
[*]Balancer shaft delete
[*]New oil pump
[*]NA flywheel
[/list]
The engine was originally put together by Vocky and has ran with no issues for just under 10k miles in my car. Link below:
https://z22se.co.uk/...w-tweaks.27119/
These engines are very rare in Europe and would be suitable for a larger capacity NA (a skimmed head and cams), or with some stronger internals for a supercharger / turbo engine (as standard the engine will take around ~300bhp, but supposedly good for ~350bhp with just some strong steel conrods).
You will need an external crank trigger wheel to run the Z22SE ECU or a different ECU to run the internal trigger wheel (same as the Saab / LSJ).
I can palletise for buyer to arrange shipping at their own cost.
£1,000.00
Cheers,
Ross
