Wheel Cleaning.
25 replies to this topic
#1 Nev
Posted 25 March 2018 - 09:44 PM
I've got about 7 years of crud on my rear wheels (with lots of deeply embedded iron filings) , how do I clean them for < £10 with minimal elbow action?!
I think I'm looking for a chemical reaction in a can...
Edited by Nev, 25 March 2018 - 09:50 PM.
#2 Paulus H
Paulus H
  • 2,063 posts
Posted 25 March 2018 - 09:57 PM
Sounds to me you will need a wheel specialist to blast off all debris and repaint.
Good luck
Paul
#3 Nev
Posted 25 March 2018 - 10:00 PM
Good luck
Paul
Thanks, but "Bah humbug" to auto professionals.
Nothing a few chemicals for £5 can't sort out I think, instead of paying someone £xxx to do the same. There are 101 cans on the shelf that claim to do the job, just looking for 1+ recommendations of cans that ACTUALLY work without melting my tyres...
Edited by Nev, 25 March 2018 - 10:04 PM.
#4 pete-r
pete-r
  • 2,771 posts
Posted 25 March 2018 - 10:01 PM
Iron x. You can use it on the wheels and bodywork. Stinks and turns everything purple but it'll do the job with a little brushing in. Then once clean smother the wheels in at least two coats of jetseal 109. Don't use wonder wheels or any of that acidic stuff or you'll have no wheels left!
Edited by pete-r, 25 March 2018 - 10:03 PM.
#5 Nev
Posted 25 March 2018 - 10:08 PM
Sounds like a possible goer, thanks Pete. Will this stuff strip my lacquer?
Any other tried and tested suggestions from others...?
Edited by Nev, 25 March 2018 - 10:10 PM.
#6 pete-r
pete-r
  • 2,771 posts
Posted 25 March 2018 - 10:19 PM
I've been using iron x for years and never had an issue, I buy it in large containers and decant into a spray bottle. I've tried stuff like bilberrys and a few others but this is the best I've found so far. Apply to a dry wheel, leave to dwell, brush into any heavy stuff, rinse and repeat. I always dry any area I want to hit again so the stuff isn't being held away from the brake dust by a water barrier. Dry the wheel with a microfibre towel and seal it well. I also use it on the calipers, lower body, exhaust tips etc and it's impressive.
#7 aquilaproejct
aquilaproejct
  • 267 posts
Posted 26 March 2018 - 09:47 AM
Ironx is OK to use on paintwork, so should be fine on the wheels
#8 chris_uk
Posted 26 March 2018 - 12:07 PM
I have used purple rain in the past but by feck it stinks! I have found wd40 or similar left on the wheels a bit really breaks down the grims.
#9 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 26 March 2018 - 12:19 PM
I got some pink stuff from the pound store in Stoke Gifford. Worked a treat on my wheels.
#10 C8RKH
C8RKH
  • 797 posts
Posted 26 March 2018 - 04:49 PM
Iron x - wash the wheels to get the easy stuff off. I then dry with a leaf blower as it gets all the water out.
Spray with Iron x and leave on. I then spray a second layer on top of the first and use a brush to agitate.  Rinse off. Blow dry. Repeat. Once clean and dry. Wax polish the wheels or add a ceramic coating to prevent the brake dust sticking in the future.
#11 fiveoclock
fiveoclock
  • 9,453 posts
Posted 26 March 2018 - 05:30 PM
Nothing is better than Blitz
https://www.ebay.co....McAAOxy3NBSf6ts
And no it doesn't damage the wheel finish because you don't leave it on for 3 hours, you follow the instructions
Edited by fiveoclock, 26 March 2018 - 05:31 PM.
#12 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 26 March 2018 - 06:40 PM
Anyone else just shocked Nev asked about cleaning?
#13 Foxy
Foxy
    I love Nev
  • 10,743 posts
Posted 26 March 2018 - 09:57 PM
Hell be scouring the TZ classifieds and joining LoT next.
Edited by Foxy, 26 March 2018 - 09:57 PM.
#14 Actus Reus
Actus Reus
  • 75 posts
Posted 26 March 2018 - 10:24 PM
Auto Glym Magma and Auto Finesse Iron Out are both at Halfords for about a tenner and do a similar job to Iron X. Or pop online and get Iron X or Bilt Hamber Karrosol. Use a wheel cleaner first then a coating of a fallout remover and your wheels should come up well.
#15 Andy_VX
Andy_VX
  • 2,050 posts
  • Interests:Cars, Boats, F1, Cycling, Home Cinema, Music.
Posted 27 March 2018 - 07:55 AM
Word of warning, Iron X smells like cat p*ss, horrible stuff but very effective! Look at Auto Finesse, all of their products are excellent.
#16 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 27 March 2018 - 08:56 AM
I have a lots of wheels with really bad dust on so have bought these three mentioned to compare and will put up my results. If you want me to try anything else say and I will buy it.
1 Bilt Hamber Korrosol 1 Litre Iron Metallic Fallout Remover BMW MERCEDES AUDI X (251858865086) Royal Mail 48 £ 14.95
1 IronX - CarPro Iron X 500ml Cherry Paint Surface Cleaner & Brake Dust Remover (181627973719) Royal Mail Tracked 48 £ 13.40
1 BLITZ ® 500ML STRONG ACID ALLOY WHEEL CLEANER FOR CLEANING ALLOY WHEELS (271160098627) Royal Mail 1st Class £ 6.95
Edited by Tony H, 27 March 2018 - 08:57 AM.
#17 slindborg
Posted 27 March 2018 - 06:56 PM
After 7 years, NOTHING will get them clean, or atleast clean enough to not look sh*t
#18 hairy
hairy
    Moonlander
  • 6,034 posts
Posted 27 March 2018 - 08:37 PM
Fiver to the local ukranian car wash place
#19 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 28 March 2018 - 06:01 AM
I have a lots of wheels with really bad dust on so have bought these three mentioned to compare and will put up my results. If you want me to try anything else say and I will buy it.     1 Bilt Hamber Korrosol 1 Litre Iron Metallic Fallout Remover BMW MERCEDES AUDI X (251858865086) Royal Mail 48 £ 14.95 1 IronX - CarPro Iron X 500ml Cherry Paint Surface Cleaner & Brake Dust Remover (181627973719) Royal Mail Tracked 48 £ 13.40 1 BLITZ ® 500ML STRONG ACID ALLOY WHEEL CLEANER FOR CLEANING ALLOY WHEELS (271160098627) Royal Mail 1st Class £ 6.95
Yeah trolls breath please. Currently use Bilt Hamber but its expensive and trolls breath seems to work in the same way and is a third of the price
#20 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 28 March 2018 - 06:41 AM
Where is it that cheap this is the cheapest on ebay:
https://www.ebay.co....HoAAOSw8-FacH9P
