Pic Of Na Top Coolant Hose Please?
12 replies to this topic
#1 Doctor Ed
Doctor Ed
  • 908 posts
Posted 04 April 2018 - 11:44 AM
heya fellas, having some issues sorting a 'steam line' on the engine outlet hose of my A20. does the standard NA top 'radiator' hose have a T fitting in it for the expansion tank? or does the steam line come directly off the block?
cheers
ed
#2 Exmantaa
  • 3,661 posts
Posted 04 April 2018 - 12:39 PM
The steam line top the tank is connected to the head via a solid outlet near the water hose outlet.
(Z22SE use a slightly different thread fitting compared to a B207 head)
Cannot link a pic here, but google for an B207/Z22SE engine image and it's easy to spot.
Edited by Exmantaa, 04 April 2018 - 12:42 PM.
#3 Doctor Ed
Doctor Ed
  • 908 posts
Posted 04 April 2018 - 12:42 PM
i have a funny feeling the A20 has the turbo coolant return plumbed into that position (banjo fitting) so theres no hardline provision for the steam line. urghh annoying
#4 Exmantaa
  • 3,661 posts
Posted 04 April 2018 - 12:44 PM
Is there not also a connection to the undersidfe of the waterpump?
#5 Doctor Ed
Doctor Ed
  • 908 posts
Posted 04 April 2018 - 12:46 PM
nope
#6 Exmantaa
  • 3,661 posts
Posted 04 April 2018 - 12:47 PM
You're right, but on the pic it looks like they use a fancy "go-through" connection for the steam outlet hose to the tank, with the turbo banjo connection sandwitched in between... :happy: http://www.vectra-c....1/US A20NHT.jpg
#7 Doctor Ed
Doctor Ed
  • 908 posts
Posted 04 April 2018 - 12:50 PM
ooohhh, thats an idea.
i dont have that fitting on mine, just a normal banjo bolt (#14 in pic above)
Edited by Doctor Ed, 04 April 2018 - 12:53 PM.
#8 Rosssco
Rosssco
  • 3,727 posts
Posted 04 April 2018 - 12:57 PM
When looking at that engine, I planned to either just cut the existing pipe (9 in the above) and use a joiner / adaptor to fit the existing rubber hose. Or, fit a T adaptor connection in between existing coolant port and hose (would just look crap with lots of clips and potential for additional leakage paths)
#9 Exmantaa
  • 3,661 posts
Posted 04 April 2018 - 01:03 PM
From memory the NA outlet hose bend has a slight higher point that breather outlet on the block, so best would be to fit the tank breather connection at that highest point there..
(you can have a fancy new custom hose-with-outlet made?? I think Dominique had a new outlet hose made-up in silicone)
Edited by Exmantaa, 04 April 2018 - 01:04 PM.
#10 Doctor Ed
Doctor Ed
  • 908 posts
Posted 04 April 2018 - 01:04 PM
hose 1 and 9 dont fit in the VX. you can use the existing NA hose, but theres no port. so cut and insert T fitting, but it gets a little awkward
ill see if i can find a fitting for the banjo bolt...
#11 Exmantaa
  • 3,661 posts
Posted 04 April 2018 - 01:11 PM
(custom silicone engine hoses here: http://www.vx220.org...a-and-sc/page-4 )
#12 Doctor Ed
Doctor Ed
  • 908 posts
Posted 04 April 2018 - 01:30 PM
or...
https://www.do88.se/...e-off-10mm.html
#13 Doctor Ed
Doctor Ed
  • 908 posts
Posted 04 April 2018 - 08:20 PM
[color=rgb(51,51,51);font-family:Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif;font-size:13px;background-color:rgb(250,250,250);]So figured a solution running a double banjo fitting[/color]
