4.17 Ratio Gearbox For Z22Se
Posted 10 April 2018 - 07:45 AM
Posted 10 April 2018 - 02:57 PM
Great upgrade for an N/a
Posted 12 April 2018 - 01:49 PM
reduced £200
Posted 12 April 2018 - 04:06 PM
Posted 12 April 2018 - 08:40 PM
yes
Posted 12 April 2018 - 09:28 PM
Posted 13 April 2018 - 05:20 AM
Posted 13 April 2018 - 06:16 AM
XY is for dual mass flywheel, so will need bellhousing changed to fit a vx220
Posted 13 April 2018 - 08:27 AM
What difference does this make??
Posted 13 April 2018 - 08:43 AM
Shorter final drive (about 5% shorter than NA gearbox, and 15% shorter than VXT gearbox). Provides shorter effective gearing for quicker in-gear acceleration.What difference does this make??
Gives you a bit more low down oomph. Especially good out of corners if you use the car on track
Posted 13 April 2018 - 09:10 AM
if you could only do a single mod to a standard vx220 then the 4.17 final drive gearbox would be my first choice
Posted 13 April 2018 - 09:55 AM
The right way to tell if it fits is by the gearbox ident code. SG or AQ are the right codes for the 4,17 with the right bellhousing iirc. I think XY also from the z22yh astra.
AQ this one
Will fit straight in I'm even going to swap the plastic slave cyl adaptor for the correct metal one.
Posted 15 April 2018 - 12:01 PM
Posted 22 April 2018 - 09:56 AM
Posted 09 May 2018 - 11:51 AM
still for sale.
Posted 13 June 2018 - 01:05 PM
Price dropped to £175.
I keep tripping up over it.
Posted 14 June 2018 - 01:22 PM
Now sold
