Recommended Oil For Stage 4 Vxt?
11 replies to this topic
#1 rabbidog
rabbidog
  • 106 posts
Posted 12 April 2018 - 07:58 PM
What oil brand/viscosity do you recommend for cars tuned to stage 4 and beyond? Also what spark plugs are u using?
#2 chris_uk
    I fancy chill
  • 9,711 posts
Posted 12 April 2018 - 08:39 PM
10/40 fully synth.
#3 ayresyy
ayresyy
  • 245 posts
Posted 13 April 2018 - 07:03 AM
 I use 5-40w fully synth, same as Chis once warmed up :happy:
#4 mbes2
mbes2
    Always a VX'er with a Old mans car
  • 8,134 posts
Posted 13 April 2018 - 07:17 AM
#5 tibby
tibby
  • 503 posts
  • Interests:POWER
Posted 13 April 2018 - 11:51 AM
Shell 10w60 Bosch FD5POR
#6 rabbidog
rabbidog
  • 106 posts
Posted 13 April 2018 - 01:05 PM
Same as by daily driver then
#7 Nev
  • 11,017 posts
Posted 13 April 2018 - 01:09 PM
As your engine is now making 50% extra heat (which is what stage 4 is if you drive it hard) and/or you see high water temps you could/should(?) consider getting a thicker oil (50 or even 60 grade in summer maybe). In the VX if you have the bottom floorpan off the oil can't as easily cool either.
Similar logic for the spark plugs, you should use a cooler running plug than OEM (due to the heat). Taking off the plastic cover in the centreline top of the cam cover can help reduce temps and thus reduce premature coil pack fatigue.
Edited by Nev, 13 April 2018 - 01:19 PM.
#8 siztenboots
  • 26,114 posts
Posted 13 April 2018 - 02:32 PM
10w40 fully synth , change more often
#9 fezzasus
  • 7,586 posts
Posted 30 April 2018 - 07:05 PM
So no one has actually recommended an oil, they've recommended viscosity grades which really mean nothing under the high shear contacts in an engine (high shear occurs when two surfaces have a large difference in moving speed).
I would recommend Shell Helix Ultra 5W-40. It has a significant number of OEM claims which, in combination, provide a more robust oil than an oil without OEM claims, and it has a high HTHS, which afford real protection in the engine
#10 Di3sel
Di3sel
  • 93 posts
Posted 30 April 2018 - 08:12 PM
I was reading a post of yours on this topic http://www.vx220.org...ne-oil/?hl=acea where you mentioned we should go for A3/B4 ACEA specification. Considering that, I have ordered Mobil Super 3000 x1 5w 40 for my VXT. Any objections on this decision?
#11 rueda
rueda
  • 97 posts
Posted 30 April 2018 - 09:45 PM
Do you recommand the same oil for a track/race use only and also a Stage 4 car ?
#12 Zoobeef
Zoobeef
    Sloe Fahy-Brookes was here.
  • 10,896 posts
Posted 01 May 2018 - 12:57 AM
I use shell helix ultra 5w40 in the Noble and the racecar. It's factory recommended for ferraris and endorsed by Tom.
it'll be good enough.
