Edited by Chris P Duck, 18 April 2018 - 05:31 PM.
Live Breakdown In Progress 🤬
Posted 18 April 2018 - 05:30 PM
Posted 18 April 2018 - 05:34 PM
MAP sensor would be the first thing to try
Posted 18 April 2018 - 05:39 PM
Fez had an issue to do with fuel... I recall it occured when the tank was low and it was hot. Running low?
Posted 18 April 2018 - 05:42 PM
Posted 18 April 2018 - 05:50 PM
Crank and cam sensors would both cause the car to turn endlessly without firing... both seated correctly and wiring look OK?
Posted 18 April 2018 - 05:56 PM
Would need nice circled images (idiots guide) to know where to look... Wouldnt they both set fault codes though?Crank and cam sensors would both cause the car to turn endlessly without firing... both seated correctly and wiring look OK?
Posted 18 April 2018 - 05:57 PM
Can you run a short OBD log to see if the TMAP is functioning as it should?
Posted 18 April 2018 - 06:10 PM
Mines a Turbo and don't know the Z22SE but read a few articles and apparently, there is no cam sensor on a Z22SE but there is a Crank sensor located behind the oil filter, below the inlet manifold, behind the starter motor
I'm sure I recall cases of crank sensor failure without codes.
Hope you get it sorted.
Posted 18 April 2018 - 06:16 PM
Posted 18 April 2018 - 06:20 PM
Posted 18 April 2018 - 06:49 PM
Offer of help is very much appreciated anyway 👍At least you're home.
Posted 18 April 2018 - 07:04 PM
Has anything been done to the car this winter? (maintenance, upgrades etc)
Posted 18 April 2018 - 07:26 PM
Only suspension related and a normal service (oil, plugs filters)Has anything been done to the car this winter? (maintenance, upgrades etc)
Edited by Chris P Duck, 18 April 2018 - 07:27 PM.
Posted 19 April 2018 - 06:24 AM
Posted 19 April 2018 - 07:16 AM
This!
I had the same thing with mine over xmas. Car just died, wouldnt restart for awhile and then when it did it wouldnt idle but would run like crap if rev'd over 1500rpm (enough to drive it back into the garage after recovery). Joe came to the rescue with a bunch of sensors and it turned out to be the MAP sensor, running perfectly after it was swapped.
This is the one to try first because you can swap it in a few mins. Its at the top of the intake manifold and held in with one bolt. Much easier than the other sensors to get to so start with the easiest!
Edited by Mattyboi, 19 April 2018 - 07:16 AM.
Posted 19 April 2018 - 01:14 PM
followed me the 0.6 miles to my house.
Could you not have pushed it?
Glad you made it home anyway
Posted 19 April 2018 - 07:04 PM
I thought the same, but wasn't impertinent enough to type it.
Edited by Nev, 19 April 2018 - 07:04 PM.
