Now The Sun Has Decided To Show Up....how’S Your Vx Running?
Posted 18 April 2018 - 06:56 PM
Posted 18 April 2018 - 09:42 PM
Edited by Strugs, 18 April 2018 - 09:43 PM.
Posted 18 April 2018 - 09:45 PM
Posted 19 April 2018 - 12:06 AM
Use mine all year round (unless rain is torrential or there's ice/snow about). Roof off mostly. So.. All fine, ta! 😄
+1 for a stage banana's turbo
Posted 19 April 2018 - 05:06 AM
I don't ever get any electrical issues like that, I'd suggest you really need to stick it in a dry garage I think, plugged in to a battery charger. Mine spends winter like that and never has a problem starting/working.
Posted 19 April 2018 - 06:07 AM
Posted 19 April 2018 - 06:45 AM
Edited by pete-r, 19 April 2018 - 06:46 AM.
Posted 19 April 2018 - 07:12 AM
Mines tip top and ready for a Highlands road trip in a couple of weeks!
I had it SC'd at the start of winter so this will be the first proper road trip since its been done. I had a MAP sensor failure over xmas but now carry a spare along with some other critical bits so I'm prepared. The main issue i have is not dash cowl as it was super glued in so had to be smashed out. No performance issues but it looks terrible without.
Posted 19 April 2018 - 08:06 AM
Posted 19 April 2018 - 08:15 AM
My car also does this! Even when it was left in a dry garage. If I leave it for 2 weeks, when it starts it judders like it's on 3 cyls for a few mins, sometimes get the fan on for first 30 mins of a journey. But when I drive it every few days it's fine, even left outside.
Throttle issue. Keeps returning to idle. Sent from my SM-G903F using Tapatalk
That sounds like loom of doom to me, easy enough fix..
Posted 19 April 2018 - 09:55 AM
Garw screen just installed but the values are all way off
Need to change a wheel bearing it seems
Need to change brake fluid as when measured would boil very easely
Also got some new engine oil since i don't know when the previous owner changed it
The cabling for my chargecooler install hasn't been insulated properly with fabric tape
But with the help of a odb bluetooth dongle to monitor values that don't display in the garw lcd, and the torque app, i've managed to cover 100km the past week wohoo!
Posted 19 April 2018 - 11:36 AM
Posted 19 April 2018 - 11:43 AM
running like a dream as always
Posted 19 April 2018 - 11:46 AM
if you get the apk for the torque pro version , you can also see the TMAP sensor , so boost and intake temps
Posted 19 April 2018 - 12:57 PM
Totally agree
Posted 19 April 2018 - 02:08 PM
Well apart from the mice getting in, chewing up my driving gloves to make a nest and gnawing away the boot trim. A visual inspection doesn't indicate anything else, so all seems fine. Took a couple of presses of the start button but eventually coughed and spluttered into life. Now looking forward to the first track day at Goodwood this Saturday. Just seen the forecast, guess what....
Posted 19 April 2018 - 03:10 PM
clunking noise from the front , wish I never took advice to fit a quick rack
booked in to BoT
Posted 19 April 2018 - 03:12 PM
Posted 19 April 2018 - 03:18 PM
Ummm. Had a knocking noise from the front end this morning, stopped under braking, turned out one of the spring plates across top of the pads had broken....decided to change pads all round, dont mind those sorts of issues, random warning lights are just frustrating! Hope you get yours sortedclunking noise from the front , wish I never took advice to fit a quick rack booked in to BoT
