I've been testing out a theory that I have a leak somewhere, going to do a proper test later and pressurize from turbo to throttlebody
Yesterday I ran with the BCS solenoid unplugged and I was expecting to run at around actuator pressure, currently got a 13psi static break. So I'd have thought I'd see around 13psi worth of boost?
I'm actually seeing basically no boost in 3rd gear and then I get a little bit in 4th when running at actuator pressure, is this normal? I would expect with turbo connected straight to actuator that I get whatever the pressure of the actuator is....?
