Hardtop Turbo And Na Any Difference
11 replies to this topic
#1 ash_gt4
ash_gt4
  • 89 posts
Posted 01 May 2018 - 06:37 AM
I am Looking to get a hardtop for my na and was wondering if there is any difference between the turbo and na hardtop?
#2 smiley
Posted 01 May 2018 - 06:45 AM
na oem is mat silver like the windows surround and has plastic lining. tubby oem is painted in car color and has padded lining. over the years many na's have been painted in car color. some turbo ones may have had a color change over time.
#3 2GOOD
2GOOD
    Old Timer zzz...
  • 4,451 posts
Posted 01 May 2018 - 06:46 AM
When new, a turbo hardtop was colour coded & the headlining was finished in material, the 2.2 was normally matt silver to match the windscreen trim with a plastic headlining unless it was a Lightning Yellow car To add: I clearly type to slowly :)
Edited by 2GOOD, 01 May 2018 - 06:53 AM.
#4 ash_gt4
ash_gt4
  • 89 posts
Posted 01 May 2018 - 07:30 AM
Cheers guy. Other than colour any difference in fitting latches etc
#5 vocky
Posted 01 May 2018 - 07:39 AM
the fixings are shared across the vx220 and some Lotus models
#6 siztenboots
Posted 01 May 2018 - 07:41 AM
rear bracket fixings on the car slightly different , metal vs plastic, iirc
#7 vocky
Posted 01 May 2018 - 07:44 AM
I think you need the plastic rear brackets on the car for a hard top ?
#8 smiley
Posted 01 May 2018 - 11:19 AM
Early NA's had the latching bracket that is bolted into the rollbar that is missing a lip to which the hardtop bracket latches on (left one)
If you do, it will have to be replaced by the version on the right.
http://www.elise-sho...l-rh-p-963.html
http://www.elise-sho...l-lh-p-964.html
Edited by smiley, 01 May 2018 - 11:21 AM.
#9 ash_gt4
ash_gt4
  • 89 posts
Posted 01 May 2018 - 12:07 PM
thanks, so would you need to change the bracket every time you switched between hard top and soft-top or would the hardtop bracket still fit an N/A soft top?
#10 smiley
Posted 01 May 2018 - 01:02 PM
no, the new bracket is for both. The original bracket came to life when people bought a new NA without hardtop. These old style are getting rare by now.
#11 ash_gt4
ash_gt4
  • 89 posts
Posted 01 May 2018 - 02:27 PM
Cheers
#12 Rosssco
Rosssco
  • 4,183 posts
Posted 01 May 2018 - 03:10 PM
You can use the metal bracket, just that the 'hook' on the hardtop side ends up rattling a bit on the metal bracket (a bit of tape usually finds its way on the end..)
