Rev Limiter On Dutch Software.
12 replies to this topic
#1 Talk-torque
Talk-torque
  • 150 posts
Posted 22 May 2018 - 08:51 AM
Did our first track day in the car at Blyton a couple of weeks ago. Great experience and the car just came alive. One problem we both had was the hard rev limiter with the Dutch software. With so mutch to think about on track, it was easy to forget the revs and hit the wall that the hard rev limiter applies. Is there a way to have a soft limiter that would be more of a reminder than a hinderence? Plan is to fit a shift light, set to a litlle below a slightly raised software limiter, but it would still be nice to have a softer ultimate limiter. Rev limiter is currently set to 6,800rpm, to be safe, but the engine is stiil gaining power there, so easy to forget up changes, in the heat of the moment!
Edited by Talk-torque, 22 May 2018 - 08:55 AM.
#2 smiley
Posted 22 May 2018 - 09:40 AM
You could try contacting Peter for a Request For Enhancement, by maybe using the eml as a notification at a lower rpm.
Untill then you are stuck with a shiftlight.
#3 CHILL Gone DUTCH
Posted 22 May 2018 - 09:56 AM
Rev limiter on standard internals with the correct injectors should be ok at 7100 rpm
#4 siztenboots
Posted 22 May 2018 - 10:08 AM
roll off the ignition timing at the top rev range
#5 Johnboyhgt
Johnboyhgt
  • 1,313 posts
Posted 22 May 2018 - 11:10 AM
Roger is on the green LSJ injectors.
#6 CHILL Gone DUTCH
Posted 22 May 2018 - 11:13 AM
Not really a good idea to increase revs to much then Blue vxr are ideal for upping Rev range Don't let duty cycle over 90% and ideally 80-85%
#7 Johnboyhgt
Johnboyhgt
  • 1,313 posts
Posted 22 May 2018 - 11:15 AM
That's why we limited to 6800 rpm. Sent from my SM-G903F using Tapatalk
#8 fezzasus
Posted 22 May 2018 - 11:23 AM
Nothing stopping you from performing a logging session with a higher rev limit (7100) and see if the lambda drops off at WOT. Then set RPM accordingly
#9 Johnboyhgt
Johnboyhgt
  • 1,313 posts
Posted 22 May 2018 - 11:28 AM
Very true. Sent from my SM-G903F using Tapatalk
#10 Exmantaa
Posted 22 May 2018 - 12:41 PM
:yeahthat:
I had no problems with my old stage 2 @ 6800rpm on the black Z20LET injectors (249 Bhp and Lambda 0.8 till rev limiter...) The green LSJ's flow 11% more fuel, so you should be fine at a higher 7100 rpm limit, but always good to check the O2 values at max rpm.
(Even better with a wideband. An do a WB learning session for the high rpm regions.)
And as said, you can lower ignition towards max rpm to lower the power there. ;)
#11 Talk-torque
Talk-torque
  • 150 posts
Posted 22 May 2018 - 02:35 PM
Thanks guys. Backing off ignition sounds like a plan, but a shift light will be added asap. ........oh, and blue injectors. 😀
Edited by Talk-torque, 22 May 2018 - 02:35 PM.
#12 smiley
Posted 22 May 2018 - 03:18 PM
Keep in mind that when switching to blue, you need to convert the connectors from EV6 to EV1.
#13 Talk-torque
Talk-torque
  • 150 posts
Posted 22 May 2018 - 08:38 PM
Thanks Smiley, will do.
