Hi,
Sorry to myther you on this subject but I am trying to fit my 4 point harnesses. I've got my wrap around harness bar fitted and already done. I've fitted my cut outs in the seats, but came unstuck when fitting the lap straps. I just ordered my eye bolts and expected to fit them into the chassis where the seat belts mount, but found that the fixings are on the seats and are too big for my harness buckle to fit.
So I've done some digging and it seems to be much better to fit the eye bolts to the chassis anyway, the query is how? I have found where the U shaped rail is behind the seats that I need to mount them too and I know you can get some expensive plates to fit underneath. You basically drill a pilot hole through the chassis rail then drill a 16mm drill hole underneath to line up with the eye bolt and the expensive plate sits underneath. Can I not just drill a 25mm hole and use a nylon nut and fit a small aluminium plate to cover the hole ?
Adam
