Aerodynamics Testing.
3 replies to this topic
#1 chris_uk
Posted 29 May 2018 - 11:03 PM
Maybe this will help some of you out.. just a couple pics from some tests i did on the new aero parts.
33120377_10156352701307731_3676720231348
33387387_10156352701242731_4909629518953
on the move
33356776_10156352701267731_1498257143155
33491342_10156352701277731_1353326585603
33403108_10156352765157731_9387598323394
33384188_10156353008662731_5433957700520
33574384_10156353008572731_6488909484981
33365463_10156352701462731_5116699031984
33937643_10156363074742731_2512820751678
33844564_10156363074737731_1392488028689
33847421_10156363074747731_5927931630218
34018837_10156363074752731_5736192161137
`basically what this shows is that the coupe keeps flow over the top with very very little separation, there is a little bit of turbulence but nothing to worry about.. the spoiler shows very very good attached flow on the underside so that is really going to be creating real downforce.. the diffuser is "ok" there is some separation at the start but it re-attaches near the end, maybe that's the gurney flap on top im unsure.
the side gurneys on the front of the arches visually push air away from the wheel arch but as soon as they stop you can see the chords fold into the arch, i have longer, narrower ones been made so they should provide some  nice deflection.
the sideskirts work by not letting air under the car, also you can see the chords are facing straight towards the rear of the car and are not trying to get underneath, the ones on the side do flow under sometimes but most of the time they stay on the side.. this shows that a lower amount of air is entering under the car.
#2 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 30 May 2018 - 07:16 AM
#3 FLD
Posted 30 May 2018 - 07:33 AM
The ones at the rear of the wing seem to be away from the wing. Might just be the pic. Have you tried changing a of a or changing speed to see how it's affected?
#4 chris_uk
Posted 30 May 2018 - 07:56 AM
The wing and coupe pics are screenshots of a video from 40-120 so you can see how they are flowing
They all stay attached..
Ill upload the proper vid when i get home.
