Race Logic Traction Control Problems
15 replies to this topic
#1 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 31 May 2018 - 12:58 PM
I’ve had the race logic traction control fitted some time now and not had any problems with it at lower speeds. Just recently at lower speeds below 30mph it’s started to kick in. Anyone else found this to happen even with one of CS filters fitted?
#2 Rosssco
Rosssco
  • 4,185 posts
Posted 31 May 2018 - 01:17 PM
Could you be getting a dodgy / intermittent signal from a wheel bearing pack or sensor wiring..?
#3 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 31 May 2018 - 01:37 PM
Could be a possibility and if anyone can shed anymore light on it will be great.
I would of thought that if I had a wiring problem then it would be happing all the time.
#4 'Buchos'
'Buchos'
  • 792 posts
Posted 31 May 2018 - 09:29 PM
I looked at my RLTC signals with a scope a while back when we were debating the need for the filter and found some signals very weak (theres a thread around somewhere). I changed all four hubs, they were pretty cheap, tried again and I was getting good strong signals from each one and no low speed activations. I did build a filter as well afterwards, but I'm not sure it's needed.
#5 siztenboots
Posted 02 June 2018 - 10:50 AM
the only thing I can think is that brake dust might have collected and built up in the abs ring causing a smaller peak to peak signal.
also had a look at your website, very interesting!
#6 Nev
Posted 02 June 2018 - 11:25 AM
What website is that - can you post up the link, sounds like I should be reading and learning something.
#7 Nev
Posted 02 June 2018 - 11:26 AM
Dave Hardwick has some experience with this, you could possibly try contacting him.
#8 hairy
hairy
    Moonlander
  • 6,066 posts
Posted 02 June 2018 - 12:35 PM
http://www.nelsonstewart.co.uk/
#9 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 02 June 2018 - 03:36 PM
New hubs were fitted last year and if that’s the case then it’s a pain if I have to keep cleaning it. Just surprised it’s only happend to me. Is there a way to switch the traction control off under 30 mph so I never have to deal with this problem again?
#10 ditonics
ditonics
    Turbos aren’t as good as NA’s
  • 939 posts
Posted 01 September 2018 - 05:32 PM
Did you ever solve this?
My ABS outputs were looked at yesterday by Emerald with a view to using the signals to feed into the ECU. Unfortunately the signal was very noisy and unusable. So I am looking for another solution to getting clean wheel speed signals.
#11 'Buchos'
'Buchos'
  • 792 posts
Posted 02 September 2018 - 09:54 AM
Hi Simon, here are the details of the filter the .de guys made for the the RLTC, its pretty easy to build for around a fiver if you want to go that way. I've put the rest of their instructions here: http://www.nelsonste...celogic-tc.html
I know its not the same system as you are using, but it may be interesting to you.
#12 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 03 September 2018 - 08:34 PM
No it didn't and hasn't done it again so can't really offer any advice tbh.
#13 The Batman
Posted 03 September 2018 - 09:21 PM
this explains why you can wheel spin in second :lol:
#14 ditonics
ditonics
  • 939 posts
Posted 04 September 2018 - 10:05 AM
And third 😂😂
#15 siztenboots
Posted 04 September 2018 - 11:21 AM
Pete used to get problems on his even in 5th on the VXR
#16 starman
starman
  • 44 posts
Posted 09 September 2018 - 05:42 PM
Do you have the LCD display for the RLTC?  If so it can display the signal from each wheel, so if it happens again you can check the display and see a drop out.
