Dutch Software - Loss Of Power And Eml On After 4Th Gear Hard Drive.
Posted 07 June 2018 - 08:22 PM
I've got a Harrop SC VX running Dutch software but was wondering if you could help? I've just driven to work in the vx and cained it off the lights and in 4th it lost power (wouldn't rev at all just idle) and pinged an EML. I pulled over and switched it off, then on again and it would rev again but EML light is still on.
I had to get to work so gently drove here and the AFR and engine temp was all healthy.
Any ideas?
Adam
PS I've never interfaced with the software as I bought the car already done. Can I read the fault with a normal Obd reader or do I need to buy a lead and download software?
Sent from my LG-H815 using Tapatalk
Posted 07 June 2018 - 08:31 PM
im guessing a p1514 code
was your water injection switched on ?
Posted 07 June 2018 - 08:33 PM
ive seen this a few times with the water injection and think its linked to the tmap, even though its to do with the throttle pedal throttle body code
Posted 07 June 2018 - 08:35 PM
Posted 07 June 2018 - 08:36 PM
Could be what i had and was boosting to much and past the max kpa i had set in my dutch software
Posted 07 June 2018 - 08:42 PM
Ive spoken to peter about this, as ive suffered with it my self and quite sure it happens due to the tmap getting to wet, other than that it could be a vacuum leak
A slow MAP sensor can definitely cause the P1514. A P1514 is set when
the theoretical MAP difference between throttle position and engine
rpm gets over 30kPA.
Posted 07 June 2018 - 08:49 PM
Could this just be a blip and can I reset it with a normal OBD reset tool?
I really do need to start learning about this software.
Posted 07 June 2018 - 08:51 PM
yes just reset it
i mainly got it on high rpm low loads
it reset straight away without issues
please read the code first and confirm its a p1514
Posted 07 June 2018 - 08:55 PM
yes, you can read the code with any obdreader.
A simple standalone device like this:
http://www.vx220.org...-obdll-scanner/
Or this:
http://cgi.ebay.co.u...em=142815938586
Edited by smiley, 07 June 2018 - 08:59 PM.
Ive had this 30 kpa limit increased on my car but i have not tested yet so when i do i will give feed back
Posted 07 June 2018 - 09:05 PM
Posted 07 June 2018 - 09:26 PM
No problem, i would rather try and help you rather than watch love island with the daughter and wife
Posted 07 June 2018 - 09:34 PM
Posted 08 June 2018 - 06:16 AM
Posted 08 June 2018 - 06:25 AM
https://www.speedste.../z22secodes.pdf
P1271 is an accelerator pedal read error. mis-match between the two opposing potentiometers (APP) in the pedal.
From the doc above, the conditions for setting this:
1) Detect a continuous or intermittent correlation fault between APP sensors #1 and #2.
OR,
2) Detect an invalid minimum mechanical position correlation between APP sensor #1 and #2.
OR,
3) Detect a short between the APPS 1 & 2 Circuits.
Possibly pedal, connector, Loom of doom connectors, ECU plug?
Posted 08 June 2018 - 10:40 AM
Posted 08 June 2018 - 12:01 PM
I'm off on Monday, so will remove clean and spray the most likely connectors.
Posted 15 June 2018 - 02:36 PM
Had the exact same symptoms on a Supercharged stage 2 car I viewed and was about to buy. Sudden loss of power and EML code.
Then upon restart it was fine but from time to time on hard pulls the same thing happened again.
Didn't buy the car and don't know if it was sorted eventually.
But loom of doom I guess is the first thing to check.
Posted 15 June 2018 - 03:03 PM
I'll take my list and electrical connector spray with me just incase.
