Trailer Tyre Pressure
12 replies to this topic
#1 Krusty
Krusty
  • 527 posts
Posted 10 June 2018 - 09:35 PM
I've got a 4 wheel trailer for the vx, any suggestions on what pressure I should have on the tyres?
#2 VincentL
VincentL
  • 133 posts
Posted 11 June 2018 - 07:02 AM
I run 3 bar on mine. Should be specified on the tire however
#3 SteveA
SteveA
  • 9,159 posts
Posted 11 June 2018 - 09:07 AM
Mine are 65 psi but it is single axle trailer and the tyres are 8 ply.
#4 swast4
swast4
  • 416 posts
  • Interests:Trackdays
Posted 11 June 2018 - 09:14 AM
Hi,
I have a Brian James trailer, with hard cover on it, weighs about 1T in total plus VX.
I rang up BJ a while back and I'm sure they recommended 65psi (I wish I wire it down) . I bottled it and stick 50psi as that kind of pressure seems excessive.
They are 6ply trailer tyres. Which I must get round to changing.........
Sent from my LG-H815 using Tapatalk
Edited by swast4, 11 June 2018 - 09:16 AM.
#5 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 11 June 2018 - 09:17 AM
Depends on the wheel/tyre size and the load.
My twin axle Brian James Minno has 10” wheels and I run them around 50psi. Total weight loaded is probably 1.4T
I’ve also replaced the cross-plys with radials and it tows better and the tyres now run much cooler! A worthwhile change!
#6 swast4
swast4
  • 416 posts
Posted 11 June 2018 - 09:25 AM
Oh right, as I've never been happy towing mine, it feels like I'm towing a house, but the trailer is like a brick shape. My trailer and car and spare tyres etc is about 2T, am I still ok to run radials?
#7 Peter VXR29
Peter VXR29
  • 811 posts
  • Interests:Bike and car track days
Posted 11 June 2018 - 10:19 AM
My twin axle brian james enclosed trailer is set at 70psi, I borrowed a triple axle rain James trailer recently and incredibly those tyres are set at 90 psi. As others have mentioned each trailer and tyre choice can vary, best to check, my trailer has a plate on it that gives you choices of tyres you can run and what pressures they should be, no idea if that's common or not.
#8 siztenboots
Posted 11 June 2018 - 11:19 AM
more load = more pressure
I normally look at the tyres marked sidewall maximum inflation pressure when cold , and set at 80% of that.
Really you need to look at axle load and tyre load rating
https://www.tyresafe...flation-tables/
#9 swast4
swast4
  • 416 posts
Posted 11 June 2018 - 08:41 PM
Wow 90psi, that's a lot of pressure, I think I may ring BJ tomoz and confirm my pressure again and ask about radials. As it sits run alot better with more pressure.
#10 hairy
hairy
    Moonlander
  • 6,066 posts
Posted 12 June 2018 - 08:00 AM
Road or track?
Edited by hairy, 12 June 2018 - 08:00 AM.
#11 swast4
swast4
  • 416 posts
Posted 13 June 2018 - 05:15 PM
Thanks for the info siztenboots. My pressure show 44psi, but I was sure it was 65psi last time I contacted BJ. I contacted them again today and they said 44psi.
My tyres are 12" and the tables start at 13 so close enough, but I have emailed the sage to update there tables.
#12 kipper
kipper
  • 2,364 posts
    Smoking various types
    of fish.
Posted 13 June 2018 - 07:42 PM
About to pump mine up tomorrow, but I usually run 70 psi in my twin axle Brian James trailer...seems excessive, but have ben all around Europe with the trailer and car with no problems... 70 psi is the recommended pressure from BJ in the case of my trailer.
#13 swast4
swast4
  • 416 posts
Posted 13 June 2018 - 08:33 PM
Yeh thats what I thought but I'm sure they've changed it.
