Torque + Obd Reader Afr?
13 replies to this topic
#1 Firthy
Firthy
  • 576 posts
Posted 04 July 2018 - 09:44 AM
Hi All,
On Smiley's advice I'm currently using a bluetooth OBD2 reader and torque app on an android phone to monitor SC intake temps on track... I can also see coolant on this as well.
I can also see the option to monitor fuel pressure on the free torque app not sure on AFR etc..
Probably a very stupid question but is anyone using torque app to monitor AFR or fuel pressure and could it be useful to check the fuel system afr etc?
Firthy
I can see an option to monitor O2 Sensor 1 Equivalence Ratio - Is that AFR?
Edited by Firthy, 04 July 2018 - 09:49 AM.
#2 siztenboots
Posted 04 July 2018 - 09:50 AM
just google for the torque pro .apk and install the full version , on the VXT this gets you extras like the map sensor
#3 Firthy
Firthy
  • 576 posts
Posted 04 July 2018 - 10:56 AM
Cheers Steve,
Just downloaded the Torque Pro App which has AFR measured and AFR Commanded.
It also stores info like the highest intake temp which could be useful :)
Does anyone know if these functions work?
Can anyone recommend what to keep an eye on fuel pressure vs fuel pressure rail etc?
Firthy
Edited by Firthy, 04 July 2018 - 10:57 AM.
#4 smiley
Posted 04 July 2018 - 11:12 AM
When torque Is started, and you browse for a new value, and it lights up light green it should be available to view.
These are the ones that worked on my NA:
http://www.vx220.org...ner-multi-gauge
Edited by smiley, 04 July 2018 - 11:14 AM.
#5 Firthy
Firthy
  • 576 posts
Posted 04 July 2018 - 12:01 PM
Thanks Smiley so no AFR etc :)
#6 smiley
Posted 04 July 2018 - 01:00 PM
Those screenshots are now 4 years old.
Not sure if a newer torque releases more info from our vx ecu today?
#7 Firthy
Firthy
  • 576 posts
Posted 04 July 2018 - 01:22 PM
Cool I will give it a go tonight !!!
#8 Jetpilot
Jetpilot
  • 355 posts
Posted 04 July 2018 - 02:47 PM
I cant recall being able to get afr's last year on Torque Pro when i had my VX (which was one bit of data i really wanted), i am pretty sure its nothing to do with torque but the data the ecu puts out to the obd.
#9 oakmere
oakmere
  • 2,143 posts
Posted 04 July 2018 - 04:15 PM
I don’t see how it can show the AFR as the ECU isn’t connected to a wide band sensor?
All it can probably show is the target AFR.
More modern cars which run wideband as std can probably show AFR.
#10 Firthy
Firthy
  • 576 posts
Posted 04 July 2018 - 06:17 PM
Hi Oakmere,
Thanks for your help, I knew someone would be a long to put me straight.
As you say I can get communicated AFR, but obviously not measured AFR 😂
Can I ask another stupid question I guess obd uses the lambda to work out the air fuel ratio.
Could you therefore display the lambda and get a reading?
I can see the 02 sensor value with engine off is 447.0 can either of these be used in a similar way?
The other value I can get is timing advance could I monitor anything with that?
Sorry for the stupid questions!!
#11 Firthy
Firthy
  • 576 posts
Posted 04 July 2018 - 09:48 PM
So after some research I can log the two O2 sensors, this is measured by voltage so high voltage equals rich.
This way I can monitor that the car isn't running lean at WOT?
I can also log short term fuel trim which should remain -0.9 - +0.9 is that correct?
I can also monitor the timing advance - would this be useful at all?
Does that make sense?
Any advice always appreciated 👍
Here's the link I found
https://youtu.be/DZPyu9WUglY
Edited by Firthy, 04 July 2018 - 09:57 PM.
#12 dominik
dominik
  • 69 posts
Posted 05 July 2018 - 06:58 AM
Does the torque app show boost pressure on the vxt?
#13 siztenboots
Posted 05 July 2018 - 08:30 AM
yes if you install the pro version from .apk file
it used to be on the basic free one, until they removed it and started charging for the app
#14 smiley
Posted 05 July 2018 - 08:57 AM
If there is one app that is worth paying for, Torque is certainly it.
Peanuts for what you get.
