Hello. Got the engine running yesterday (its been sitting for 5 years!) and have been doing some checks today, getting it up to temperature etc..
For the first few minutes the AFR on the wideband is good, a little lean 14.8/9, but after a few minutes it goes full rich, 11 or so
Have made a log of it here https://ufile.io/wvj9u and the map is here https://ufile.io/z3yz0 and also screenshot below.
I have made the conclusion that the primary lambda is faulty since it drops below 0.5v suddenly (for no reason, I didn't touch anything), indicating lean, but both the secondary and wideband then indicate rich. My WB sensor is linked in to the EGR pin, and to get the actual afr the formula is AFR=(V*2) + 9 ... so lower voltage means rich
Please let me know any thoughts before I go and order a new primary lambda
