Any idea which other motors run the same sensor
Alternatively if anyone has a spare original sensor?
Cheers
Ed
Edited by Doctor Ed, 21 July 2018 - 07:57 AM.
Posted 21 July 2018 - 07:53 AM
Posted 21 July 2018 - 09:50 AM
Saab B207 also uses a similar sensor for the coolant
Posted 21 July 2018 - 10:11 AM
Posted 21 July 2018 - 03:33 PM
I think on my Omex it was 1v to 4.8v
Posted 21 July 2018 - 10:58 PM
Ehhhh... You probably have issues with the Stack reading the temperature signa?
OEM Stack dash needs a PWM signal from the ecu, not a proportional voltage...
Posted 22 July 2018 - 09:53 AM
Posted 22 July 2018 - 10:09 AM
maybe the turbo dash just uses a plain old dumb NTC resistor
Posted 23 July 2018 - 01:21 PM
Coolant temperature is transmitted using a PWM signal from the ECU.
ECU has a coolant temperature sensor/NTC (B61) that connects on pin 38: https://www.speedste... Z20LET - 1.pdf
It processes the data and connects via X3 to the dash pin A6, just like the Z22SE: https://www.speedste...m/Instument.pdf
Both the Motronic (Z20LET) as the Multec (Z22SE) do it this way. AFAIK there's no difference in this respect.
Alternative circuit here: https://arc.seloc.or...ge=2#pid5242375
Or you can implement it probably with an Arduino or even (severe overkill) a Pi to generate the correct PWM signal from an NTC sensor input.
Posted 23 July 2018 - 01:28 PM
this ties is with the work I did on the turbo loom and ecu pin-outs
so are we saying that there is no second water temp sensor at the front?
Posted 23 July 2018 - 05:49 PM
We made a similar circuit with a PIC to make the PWM signal to the Stack.
Posted 23 July 2018 - 07:27 PM
Posted 23 July 2018 - 08:29 PM
im inclined to ignore the temp guage in the stack then, and just OBD this stuff to my phone
That is BY FAR the easiest solution! and monitor together with IAT.
We build the circuit with a PIC and calibrated temps with a lookup table, but we only installed that on my mates car (LSJ ecu). I'm running already 2 (maybe 3?) years without a fuctioning ECT gauge on my Stack dash. One thing less to worry about.
