Bosch Fuel Injectors
11 replies to this topic
#1 jim61
jim61
  • 384 posts
Posted 27 July 2018 - 02:04 PM
Hi all,
In the throws of gathering bits for a project and have a few queries the search function hasn't shed much light on !
Anybody know where to source adaptors for EV 14 injectors into a Z22 head ?
Also any idea if the plug on green LSJ injectors is compatible ?
Many thanks in advance.
Jim
#2 smiley
Posted 27 July 2018 - 02:27 PM
oem plugs (EV6 format) fit oem injectors, the black turbo injectors and the green lsj injectors.
All others require your connectors to be converted to EV1 format.
Edited by smiley, 27 July 2018 - 02:28 PM.
#3 jim61
jim61
  • 384 posts
Posted 27 July 2018 - 02:52 PM
Thanks smiley, any thoughts on the adapter / insulator where the injector goes in to the head ?
#4 smiley
Posted 27 July 2018 - 10:16 PM
The are multiple parts in the setup (at least in my EV14 conversion)
First the grey insulators are from a GM ACDelco kit 217-2762
When you add those, the whole fuelrail get's raised, and no longer fits
On my setup i added aluminum spacers (on the left)
These spacers are part of other type of fuelrails, like for example the Z20net one.
I am not sure to which other rails they come, and what the part number for it is.
Last is the EV14 itself. Exmantaa got them for me, and mentioned they are a specific edition that included a part i needed.
I never fully underfstood that part. I will ping him and ask him to explain the ev14 edition you need, and maybe an ebay link.
Edited by smiley, 27 July 2018 - 10:25 PM.
#5 The Batman
Posted 27 July 2018 - 11:34 PM
I have the fuel rail spacers and grey insulators if you need them
#6 jim61
jim61
  • 384 posts
Posted 28 July 2018 - 07:38 AM
Thanks again smiley, did find these pics in search but it's always good to hear from someone who has first-hand experience 👍
The Batman - source of all things VX 😀 pm on the way
#7 fezzasus
Posted 28 July 2018 - 07:58 AM
The Bosch injectors you describe still have an adaptor which is the black section above the injector tip. These alone adapt them for LSJ heads. I believe this makes the grey aluminium section and fuel rail spacers redundant. In my case I am just using the Bosch injectors shown on the left (from left to right spacer at bottom, no spacer, spacer at top):
Cobalt_f6fbebb7-d4d4-406b-bcd9-32c489d3e
LSJ specific injectors can be ordered here: https://fuelinjector...ultivalve-heads
#8 jim61
jim61
  • 384 posts
Posted 28 July 2018 - 09:58 AM
Always impressed with the depth of knowledge on this forum !!
Thanks again ☺
#9 larres
larres
  • 183 posts
Posted 30 July 2018 - 06:42 AM
Correct adapters can be found here:
http://www.finjector..._injectors-219/
I bought the purple ones for the black bosch injectors which you can see on fezz pictures.
#10 jim61
jim61
  • 384 posts
Posted 16 December 2018 - 12:51 PM
Revival time 😊
Do these injectors have a proper orientation ? They aren't located in one particular direction by the rail clip like lsj injectors, obviously cant spin around much due to the plug but would be nice to have em pointing the "right" way
Thanks again
#11 siztenboots
Posted 16 December 2018 - 12:58 PM
yes the dual spray cone should match the inlet ports
#12 jim61
jim61
  • 384 posts
Posted 16 December 2018 - 01:04 PM
So the plug needs to be in the same position as original ?
