Had my cdl module out and away to have the relays replaced on it.
no problems were found with the module however i had the relays replaced as a precautionary anyway as they will likely fail at some point.
The central locking works as it should from the button on the column however when i try to use the fob it will only unlock the doors... i cant seem to get it to work for whatever reason.
Does anyone have any ideas/have they heard of similar issues?
cheers
