4.17 Fd Gearbox
Posted 05 September 2018 - 03:12 PM
But if bell housing needs to be changed on a other type it's possible
Posted 05 September 2018 - 03:33 PM
Posted 05 September 2018 - 03:35 PM
Max was this the GB that we previously discussed?
Posted 05 September 2018 - 03:36 PM
Posted 05 September 2018 - 03:37 PM
It isn't a 4.17 based on that AW code IIRC unless you've had it reworked since
Edited by Raptor, 05 September 2018 - 03:38 PM.
Posted 05 September 2018 - 03:39 PM
Posted 05 September 2018 - 03:41 PM
yeah remember our discussion (although this was 2016)? you can faintly see AW on the main gearbox casing. That's why I had to return it to you unfortunately.
Edited by Raptor, 05 September 2018 - 03:41 PM.
Posted 05 September 2018 - 03:42 PM
Posted 05 September 2018 - 03:46 PM
going back a bit now in my memory but AW was an odd code for this GB but Vauxhall confirmed to me at the time that the AW GB. does not have a 4.17 FD. I think some Zafira's were fitted with this GB but never a VX220
Edited by Raptor, 05 September 2018 - 03:46 PM.
Posted 05 September 2018 - 03:51 PM
Posted 05 September 2018 - 03:53 PM
This is the page that Vocky sent me a while ago - https://www.opel-inf...triebe/f23.html and AW isn't featured unfortunately.
If you remember, I bought your GB then spotted that it had AW on the side before I was going to fit it and so had to return it. I spoke to the GB people you used to refurbish it and they hadn't put a 4.17 drive in it either.
Posted 05 September 2018 - 04:04 PM
SG is a 4.17 z22se 4.17 box
AQ is also a 4.17 zaf gearbox
AW is an Astra 3.95 box
Posted 05 September 2018 - 04:07 PM
Posted 05 September 2018 - 04:11 PM
if you buy a XY Signum gearbox you will need to replace the bellhousing because it is for the dual mass flywheel and the slave cylinder sits too far away from the clutch with a z22se clutch/flywheel
Posted 05 September 2018 - 04:30 PM
Posted 05 September 2018 - 04:45 PM
I’ve found him a couple now. They won’t except his half price offers and now he’s in a strop
that one was from latvia
Posted 05 September 2018 - 05:13 PM
Posted 05 September 2018 - 05:18 PM
AW wa are also fitted to a zafira turbo but was 3.95
