Vxt Power Increase
Posted 19 September 2018 - 10:00 PM
My current spec:
52k standard vxt engine
Vxr turbo
MMG large intercooler
Courtenay sport intake with elbow
Piper cross panel filter
Helix 4 paddle clutch
Lightened flywheel
Angel tuning map
De cat pre cat,
Miltek centre with 200 cell cat
Larini back box
Now it’s never been on a rolling road so I don’t know the power level it’s at currently but what’s the best mods next? I have a set of vxr injectors ready to fit. Not sure if I need to go to vxr hybrid turbo of some description or K06? What do people advise? The intake bits are 70mm I would assume.
Posted 19 September 2018 - 10:11 PM
Charge cooler
Fuel pump
Injectors
Cooler plugs (iridium 7 probably)
I don't know when the 70mm intake pipework/MAF and 2.5 inch exhaust become a limitation, but would imagine you could get 300hp with current setup + my list above.
Posted 20 September 2018 - 05:47 AM
K06 turbo (or just a bigger compressor wheel) + injectors + remap = 350 HP. You have to make sure you keep the torque down < circa 330 ft/lb or your rods will die.
If you want more power than that then it becomes expensive in time + money as you need to build a new tougher engine.
Edited by Nev, 20 September 2018 - 05:48 AM.
Posted 20 September 2018 - 09:19 AM
Posted 20 September 2018 - 09:24 AM
no change as the turbine is same
I would remap that with the VXR injectors and aquamist setup.
Just fit a hybrid CHRA with your choice of compressor wheel , or go bigger and get a machined housing.
Posted 20 September 2018 - 05:44 PM
I would not want the aquamist... I use it as a daily and find myself at wide open throttle allot :-) I don't want to worry about water/meth and it running out all the time.
Posted 20 September 2018 - 05:49 PM
Map see how the drivabilty is also, next steps get more expensive in the scheme of things
Posted 21 September 2018 - 07:40 AM
What’s the lag like on a K06 turbo?
Almost non existent, particularily if you have OEM cams that are desperately trying to induce low RPM torque as well.
Edited by Nev, 21 September 2018 - 07:41 AM.
Posted 25 September 2018 - 03:34 PM
Intercooler wont work
me and Dave having been working on this style setup for ages. Biggest intercooler helps but still no good for a 300bhp car, stage 3 max!
Basically I would do what Siztenboots said.
Also you wont go through that much water injection on the road. I only done 25L in a year LOL. Track use yes, but a 300bhp car on the road you wont be on the loud pedal for more than a few seconds before you run out of road or another car gets in your way
The only way for a true 300bhp is meth or charge cooler.
You will need a 80mm MAF and VXR injectors.
Inlets will be too high to hit a genuine 300bhp.
To get over over 300bhp you will need a 3" exhaust but the 2.5 should achieve around 300bhp
Posted 05 October 2018 - 01:20 PM
What about if you've only got the standard intercooler?
For a 300bhp build would you go chargecooler or water injection?
Posted 05 October 2018 - 09:00 PM
Posted 07 October 2018 - 01:44 PM
Charger cooler if you can afford it
if you cant water injection with std intercooler should be fine
