My N/A is showing the following codes on my cheap handheld OBDII scanner
P0378 timing reference = high resolution signal B intermittent or erratic pulses
C3F00 manfacturer control
P0312 cylinder 12 misfire !!!! no idea on that
P1900 manufacturer control
Would I be right in assuming there are two crankshaft position sensors? ie A and B for crankshaft position.
the car starts up ok runs fine will even rev no problem from throttle input. After a short time it drops on to two cylinders and into limp mode ie I cannot get it to rev at all just sits there at approx. 1000rpm.
I am hoping someone can a confirm there are two sensors therefore should be sensor B failing when getting hot re code P0378
Or can someone point me in the right direction for finding the z22 codes
